intake air filter victory vision
adolfoch
Posted 2014-08-18 12:04 PM (#165383)
Subject: intake air filter victory vision
CARTAGENA Spain
how often you have to clean the filter top air
adolfoch
Posted 2014-08-18 12:06 PM (#165384 - in reply to #165383)
Subject: Re: intake air filter victory vision
CARTAGENA Spain
I have put the air filter lloyzd
Haze_Gray
Posted 2014-08-18 2:06 PM (#165391 - in reply to #165383)
Virginia Beach, VA
These are K&N type filters. K&N says that they can go as long as 50,000 miles between cleaning depending on riding conditions. I've used K&N before and I clean them prior to each riding season, which I ride about 10,000 miles or so a year. If you want to know for sure ask..........Lloydz.
Posted 2014-08-18 2:06 PM (#165392 - in reply to #165383)
I asked Lloyd that when I first installed mine; he said to replace it every 60,000 miles; or more often if you ride in dusty conditions.
adolfoch
Posted 2014-08-19 12:20 PM (#165409 - in reply to #165383)
CARTAGENA Spain
I have put the top air filter lloyzd, the first model took one carrying a kind of foam between two metal plates, and not that product should I use to clean it. I'm thinking of buying the current model have to be cleaned with K & N products
jeffmack
Posted 2014-08-19 1:42 PM (#165411 - in reply to #165383)
I clean and oil my filter every 10k miles with the K&N recharge kit. Cheap and easy. 1 kit lasts for 4-6 cleaning and re-oils
southjerseyrider
Posted 2014-08-19 4:52 PM (#165412 - in reply to #165383)
Subject: RE: intake air filter victory vision
Vineland, NJ United States
I have the current Lloyd's model (hour glass shape), I pulled it out to clean it at 30,000 miles and it wasn't even dirty.  So I wouldn't worry too much about it.
Posted 2014-09-08 7:46 AM (#165791 - in reply to #165383)
when its dirty.. you cant go by someone elses miles or some one eles's results.. its based on the area you ride and how dirty it gets during that time
tmoore
Posted 2014-09-11 5:32 PM (#165839 - in reply to #165383)
Madison/Huntsville, AL
I've got the Ness filter in front and the Lloydz on top. I'm going to let the front filter be my guide. I expect to get 10's of thousands of miles using the pair.
I haven's thought about the K&N in the Vegas for years. I may invest in a 'service'/'recharge' kit for it and be ready for the vision filters down the road.
Posted 2014-09-11 6:53 PM (#165840 - in reply to #165383)
Top filter doesn't get that dirty but then it depends where your riding. Lot of dirt roads or dusty country side will make it dirty.
Last fall I was ridding a lot of farm roads when farmers were bring in there corn crop. Never thought about it but is the spring I pulled the dash and found
a leaf cough in the filter.
adolfoch
Posted 2014-09-12 5:28 AM (#165842 - in reply to #165383)
CARTAGENA Spain
I HAVE REVIEWED AND FILTER WITH MY 8000 KM AND IS CLEAN, VOLVERE A REVIEW ABOUT 12,000 KM.
