Head Light Lens Melting in Fairing
Rondavis800
Posted 2015-11-08 1:55 PM (#176572)
Subject: Head Light Lens Melting in Fairing
, NC United States
Went riding couple hours, head lights on low beam, see picture.
I did notice lights appeared bright on road but was dusk when got home, normal temp day around 70f, after walking in garage next morning to find to melted spots on the head light lens cover.
I've felt a little heat before from bulbs and assumed normal.
I can only imaging the regulator is not working and the lights are receiving the total amperage from the charging system.
Let me know if anyone has ever seen this before and guess where I need to start to fix. Ron
(Victory Head Light Lens Melted.jpg)
Attachments Victory Head Light Lens Melted.jpg (32KB - 0 downloads)
Posted 2015-11-08 2:43 PM (#176573 - in reply to #176572)
Subject: Re: Head Light Lens Melting in Fairing
are they the Stock bulbs??
nailer
Posted 2015-11-08 4:08 PM (#176574 - in reply to #176573)
Albuquerque, NM
Got a little spot like that on the left side????
(IMG_20151108_150617.jpg)
Attachments IMG_20151108_150617.jpg (75KB - 1 downloads)
Posted 2015-11-08 5:44 PM (#176575 - in reply to #176572)
you don't say what year it is. Thats a NO NO.
Turn key on and look at volt meter that will tell you if battery is good. 12v not start bike gauge should be 14.2v that tells you bike is charging. Over 14.2v
that is not good. Your regular might be bad or your stator.
If the headlight was getting to much juice so would all the other lights.
New headlight is $500 bucks.
This dealer had one on close out table for $200 you would have to call them http://www.motoprimo.net/
Rondavis800
Posted 2015-11-09 4:49 AM (#176577 - in reply to #176572)
, NC United States
Thanks is a 2012, 3900 miles, did keep on battery tender since don't get to ride as much as would like.
Rondavis800
Posted 2015-11-09 4:50 AM (#176578 - in reply to #176572)
, NC United States
Also yes all stock including bulbs. Will check volts but not back for few weeks.
Posted 2015-11-09 7:13 AM (#176579 - in reply to #176572)
i have a 2011 vision. i just wanted to see if there was any part number differences between 2011 and 2012 and there is..
2012 - 2410971 Headlight, Halogen [Incl. 4]
2011 - 2411430 Headlight, HID
this part number are NOT for the bulbs... but the ITEM #1 http://parts.polarisind.com/images/VIC/HEADLIGHT/10VN.gif
beemerdad2@yahoo.com
Posted 2015-11-09 9:34 AM (#176580 - in reply to #176572)
Subject: RE: Head Light Lens Melting in Fairing
Wow..that is something! I've never seen anything like that before and sure hope these new LED's I installed don't get that hot!
Rondavis800
Posted 2015-11-12 6:53 AM (#176592 - in reply to #176572)
, NC United States
The volt meter is reading 15V, I did keep the bike stored on a battery tender, didn't think this would hurt anything, but guess battery at full charge and system pushing 15V, anyway will have to replace lens and check bulb types later in Dec, will report eventually how problem is solved, but will remove tender and run battery down below 12v before riding again. Lights still come on etc.
hawaii
Posted 2015-11-12 10:26 AM (#176593 - in reply to #176572)
I have a 2008 got one melted spot on left side of bike if sitting on it. All stock. Called Victory... No help since I have no dealer on Maui ...never on a battery tender btw.
(image.jpg)
Attachments image.jpg (96KB - 0 downloads)
