kuryakyn 4710 run-turn-brake controller help
drdarren
Posted 2010-08-01 2:14 PM (#66049)
Subject: kuryakyn 4710 run-turn-brake controller help
Florida
so i bought the kit as well as the 99 led stingerz for my 08 vision. i got the stingerz in no problem but i am having issues installing the kuryakyn. i looked at the link with pictures but the person who put it up said he was only connecting it to affect the trunk. i also read the kuryakyn instructions which are very simple but i need to know which color wires do which function. Here is what i need to know:
wiring for:
left turn power
right turn power
taillight "run" power
taillight "brake" power
also, the controller has two adapter plugs in it, which one do i attach the load equalizer to(or dont i use it)
also anything else you can offer is appreciated.
I am going to post this on another site as well, just in case of different users.
thanks
d
LIVV
Posted 2010-08-01 3:23 PM (#66051 - in reply to #66049)
Subject: RE: kuryakyn 4710 run-turn-brake controller help
Nalcrest, FL United States
Hi D, If you scroll down to the end of the tutorial from Ezra you will see the color codes used. You should not need the equalizer with this installation. Just make sure you are tapping into the correct wires under the seat. The pictures can be a little confusing. I just did this mod a few weeks ago and have not had any problems with my lights or Cruise control. The lower lights in the V part of the tailights will work the same as before. only the trunk lights will change. If you have a manual you should be using it to help you along. Good Luck! If you need any other info just ask. We are all here to help each other.
Chuck (LIVV)
drdarren
Posted 2010-08-01 6:03 PM (#66071 - in reply to #66051)
Florida
alright, so i think i did every thing right and it is all working. one thing, do i need the load equalizer. the person who responded said he did not think so, but anyone else who has put it on, i would appreciate your feedback as well.
thanks
darren
Posted 2010-08-01 7:02 PM (#66074 - in reply to #66049)
Subject: Re: kuryakyn 4710 run-turn-brake controller help
If you just side tapped the wires, you will not need the equalizer.
Ride Safe
drdarren
Posted 2010-08-01 7:55 PM (#66079 - in reply to #66074)
Florida
ok thanks. all is good
Zeke
Posted 2010-09-07 4:54 AM (#68840 - in reply to #66049)
Hey could you e-mail me acouple pictures of your with the light kit. I've got a Florada Joe lights for mine but I'm treading lightly on self installation. I have white lights for my black 99 Vision Tour. It'll look bad azz when they get put on.
fred921
Posted 2013-01-19 10:11 PM (#129807 - in reply to #66074)
Springfield, IL
Hopefully you'll get this soon, I've gone through and connected everything and checked it twice. I am still having problems with the signals. The right signal is fine but when I activate the left signal both sides flash and if I hit the brakes more than once nothing happens. Is there anything that I may have missed? Any and all help is needed.
Posted 2013-01-20 6:22 PM (#129837 - in reply to #66049)
drdarren - 2010-08-01 2:14 PM so i bought the kit as well as the 99 led stingerz for my 08 vision. i got the stingerz in no problem but i am having issues installing the kuryakyn. i looked at the link with pictures but the person who put it up said he was only connecting it to affect the trunk. i also read the kuryakyn instructions which are very simple but i need to know which color wires do which function. Here is what i need to know: wiring for: left turn power right turn power taillight "run" power taillight "brake" power also, the controller has two adapter plugs in it, which one do i attach the load equalizer to(or dont i use it) also anything else you can offer is appreciated. I am going to post this on another site as well, just in case of different users. thanks d
Your doing electrical with out a meter no your not are you
fred921
Posted 2013-01-20 10:22 PM (#129847 - in reply to #129837)
Springfield, IL
I did use a circuit tester since I no longer have the stock wire harness. My next step will be to make sure that I tapped the correct lines.
wrr1home
Posted 2013-01-21 3:29 PM (#129885 - in reply to #129847)
When checking these out... make sure your switch is "ON" not in "ACC"!
I've had mine for a few years and it still does weird stuff in "ACC", but functions perfectly with the switch "ON"!
