What size wrench do I need??
excelboy10
Posted 2009-09-01 8:21 PM (#43059)
Subject: What size wrench do I need??
Birmingham, AL 08 MC Tour Premium 2012 Bronze Mist
No, this isn't an ad for viagra or something similar.
I'm having the front tire replaced and I'm trying to get the wheel off. I've got the Vision shop manual and I can't seem to find the specs for the front axle. Big allen, I'm guessing a 15mm. I've got to go and buy and not sure if they make sets that cover this or if I'll just wind up getting one wrench.
Thanks in advance!
Posted 2009-09-01 8:42 PM (#43065 - in reply to #43059)
Subject: Re: What size wrench do I need??
5/8 allen - don't even bother looking for the metric size as it is exactly the same as the 5/8's and you'll find that a lot easier. picked up one at sears; genuine craftsman for 1/2 drive.
kevinx
Posted 2009-09-01 8:42 PM (#43066 - in reply to #43059)
Subject: RE: What size wrench do I need??
excelboy10 - 2009-09-01 8:21 PM
Thanks in advance!
Close..........
Axle is a 16mm which is the same as a 5/8
etspastimes
Posted 2009-09-02 7:07 AM (#43083 - in reply to #43059)
Salisbury, NC
And you can order or find that size at Sears. It is where I bought mine. ET
Prime Power
Posted 2010-07-18 6:26 PM (#64808 - in reply to #43059)
Just ordered a set including the 5/8 from Sears. Knew I would find out the size needed here. Thanks
Posted 2010-07-18 8:39 PM (#64814 - in reply to #43059)
I got a kit of them Allen sockets from harbor freight for $9.99. More sizes than I need but good deal for $10
rf43mn
Posted 2010-07-19 12:52 PM (#64846 - in reply to #43059)
Willmar, MN
Ok...but is there loc tite on it? I tried taking mine off to change fork oil, Didn't have the hex bit so I double nutted a bolt and used that. Just twisted the head off. Yes, the pinch bolts were loosened. So I ordered a set of hex wrenches and I'll try it again.
Posted 2010-07-19 12:57 PM (#64847 - in reply to #43059)
there shouldn't be, and yes, ripping the head off does not surprise me. Get the hex wrench. 5/8.
lowtone9
Posted 2010-07-20 5:32 PM (#64919 - in reply to #43059)
If you have a spark plug socket, stick an extension in it backwards and the other end, the end with flats, will fit. You might have to remove the rubber grommet or whatever from the socket.
edit: oops, doesn't fit on this bike, sorry. On a lot of the japanese bikes that hex is 24mm, and the socket fits perfectly. This is smaller, probably 15 mm or 5/8 like the dudes said. But if you ever buy a yamaha...
Edited by lowtone9 2010-07-20 5:40 PM
Posted 2010-07-20 6:49 PM (#64922 - in reply to #43059)
I used a chisel that was 5/8 size.
