When did Ma Vic solve the temperature readout problem?
Lone Ranger
Posted 2014-11-19 6:43 PM (#168810)
Subject: When did Ma Vic solve the temperature readout problem?
Cleveland, GA
As I was looking through some other posts, I saw a picture that Rollin' posted, showing 29 degrees F. on the display, and I realized that apparently Victory has fixed the early-on issue with the temperature gauge.
The early Visions had a design bug where anything under 30 degrees displayed a minus sign instead of the first digit. This morning it was 20 degrees when I rode to work and I watched the numbers roll down after I left my garage:
Assumed actual / Indicated
33 / 33
32 / 32
31 / 31
30 / 0 or -
29 / -9
28 / -8
27 / -7
26 / -6
25 / -5
24 / -4
23 / -3
22 / -2
21 / -1
20 / -0
Unfortunately, it didn't get any colder and I didn't get the chance to see how it would do in the teens.
My Vision is one of the first 2008s delivered. I received mine in October 2007.
Edited by Lone Ranger 2014-11-19 6:47 PM
Posted 2014-11-19 7:07 PM (#168811 - in reply to #168810)
Subject: Re: When did Ma Vic solve the temperature readout problem?
It was from -1 to -7 on my way to work.
Posted 2014-11-20 6:16 PM (#168822 - in reply to #168810)
If you pull your windshield aluminum V trim and with a flashlight look behind the left mirror. You'll see a black wire that is in a slot. Pull it out some how and on the end of it is a electrical thermal end. Put it some place below the gas tank. You now will be 99% correct on the temp. I did mine three years ago and zip tied the wire to the overflow tube. Check with smart phone and you'll see how accurate your gauge can be.
(temp.jpg)
Attachments temp.jpg (40KB - 1 downloads)
lennyb
Posted 2014-11-21 6:42 PM (#168837 - in reply to #168810)
Perry Hall, MD
Been looking at the minus numbers for years and now I'll know what the temperature actually is (at least down to 20). Thanks for the cross-reference.
Rollin'
Posted 2014-11-22 8:18 AM (#168841 - in reply to #168810)
Subject: RE: When did Ma Vic solve the temperature readout problem?
, WI
I have a 2010 Vision -
jimtom
Posted 2014-11-22 10:12 AM (#168842 - in reply to #168810)
Sand Rock, AL United States
mine has never worked below 30
MaddMAx2u
Posted 2014-11-22 2:59 PM (#168844 - in reply to #168810)
Orlando, FL
If you use Vic Oil, it will be spot on correct all the time!!
lennyb
Posted 2014-11-22 5:46 PM (#168845 - in reply to #168844)
Perry Hall, MD
MaddMAx2u - 2014-11-22 3:59 PM
Well then I've been screwed. I always use Vic oil and gauge is still off. Wait till I see the dealer. LOL
Posted 2014-11-22 5:57 PM (#168846 - in reply to #168810)
What now I have to change oil in the temp gauge. Would Mc Donalds FF oil work
Rollin'
Posted 2014-11-22 8:36 PM (#168847 - in reply to #168810)
, WI
It only works with a car tire!
