12 volt accessory plug in trunk/cc tour
   Discussion -> Cross Country / Cross Roads Tech ReferenceMessage format
AzShaker
Posted 2012-09-21 12:02 PM (#124043)
Subject: 12 volt accessory plug in trunk/cc tour
No power to this outlet. Plugged into it and it made a pop noise. The 10 amp fuse is good, one under panel at front of engine. The outlet in the leg pant, 12 volt works, where i-pod connection is.
Owners manual is just showing the one fuse, help. Thanks
