Posts: 185 Nebraska | Replacing the stock '08 comfort windshield what is the size equivalent in a Cee Bailey's |
Posts: 1229 Rancho Cucamonga, CA | The stock size is 18".
The Cee Bailey 18" has a little different profile then the OEM. The bottom curves at a different level. When your windshield is down, it looks like it's up. When it's up, it really looks funky.
Unless you want dark tint, go with a 7jurock winshield if you go with 18". If you go 16" or smaller, then it won't be an issue.
You can see how the 18"Cee Bailey (dark tint) matches up to the OEM windshield.
Edited by Nozzledog 2011-09-29 10:47 PM
 (CB below OEM.jpg)
 (In the down position.jpg)
 (TransFront.jpg)
 (Trans3.jpg)
CB below OEM.jpg (47KB - 6 downloads)
In the down position.jpg (34KB - 2 downloads)
Posts: 231 Desert Hot Springs (Palm Springs area), CA | +1 on 7Jurock. I put on a 15.5" for my big trip to Oregon / Idaho / Utah and it was great. This was instead of the 13.5" Ness sheild. I got the light gray tint and it looks great. |
Posts: 102 Orlando | Nozzledog - 2011-09-29 11:42 PM The stock size is 18". The Cee Bailey 18" has a little different profile then the OEM. The bottom curves at a different level. When your windshield is down, it looks like it's up. When it's up, it really looks funky. Unless you want dark tint, go with a 7jurock winshield if you go with 18". If you go 16" or smaller, then it won't be an issue. You can see how the 18"Cee Bailey (dark tint) matches up to the OEM windshield. I was using the 7jurock in clear. After I had the silver blacked out and the blue flames added, I no longer liked the clear screen. I went with the stock height Ness Flip in the smoked finish. I have loged about 3k with the new screen and love it. Wife says it feels better than 7jurock and 150% better than OEM. Plus, it just looks cool!
 (smallflames.JPG)
Posts: 185 Nebraska | If i want comparable to stock in Bailey's go with the 16 correct ?? |
Posts: 1229 Rancho Cucamonga, CA | The first picture I posted shows the OEM windshield on top of an 18" Cee Baileys. You will notice that the Cee Baileys is just a little shorter than the OEM but wider. To get the same height, you would need 18.5" or 19" You will still have to put up with the poor fit at the bottom of the windshield though. All Cee Baileys over 16" have this problem. |
Posts: 231 Desert Hot Springs (Palm Springs area), CA | hdfed - 2011-09-30 10:53 AM
Nozzledog - 2011-09-29 11:42 PM The stock size is 18". The Cee Bailey 18" has a little different profile then the OEM. The bottom curves at a different level. When your windshield is down, it looks like it's up. When it's up, it really looks funky. Unless you want dark tint, go with a 7jurock winshield if you go with 18". If you go 16" or smaller, then it won't be an issue. You can see how the 18"Cee Bailey (dark tint) matches up to the OEM windshield. I was using the 7jurock in clear.? After I had the silver blacked out and the blue flames added, I no longer liked the clear screen.? I went with the stock height Ness Flip in the smoked finish. I have loged about 3k with the new screen and love it.? Wife says it feels better than 7jurock and 150% better than OEM. Plus, it just looks cool!
HDFED, could you give us the measurement from the top of the windshield to the bottom. The ads say that the Ness Flip is the same size as stock (17.5") but it sure look smaller. Thanks, -Jeff |
| maddog - 2011-09-29 8:52 PM Replacing the stock '08 comfort windshield what is the size equivalent in a Cee Bailey's You measure your windshield and then buy one that you like. Vision have came with different sizes from what I can tell.
Posts: 185 Nebraska | Ended up ordering the 7jurlock..Thanks |
Posts: 1229 Rancho Cucamonga, CA | JS5Owner - 2011-09-30 12:15 PM
I think they mean stock Ness Vision Height (14.5"). It does look shorter than Stock Vision Tour height.
 (Flip.jpg)
Posts: 231 Desert Hot Springs (Palm Springs area), CA | Nozzledog - 2011-09-30 7:12 PM
My Ness Vision is 13.5" that is why I went with a 15.5" 7jurock as I wanted 2 more inches. It works great! Here in the Palm Springs area I love the short shield during our 100+ degree days. But when I went on my trip I figured that a larger one would be best... it was! |
