| Just picked up my new vision from dealer on my way home my radio volume was acting erratic and so was my spedo. I have less than 100mi and my dealer is closed. They installed the ipod connectivity cable |
Posts: 494 Akron Ohio area | How would we be of assistance to you?
You know it has to go back to the dealership.
Have them disconnect the 2 into 1 IPod cable and see if that corrects it.
My guess is they connected the cable incorrectly. |
Posts: 1365 Central Maryland | Pop out the rubber grommet; that the iPod cable runs through in the storage compartment. Gently pull the cable; and ease the two connectors out of the hole...and check the two connectors and make sure they're plugged in securely. |
Posts: 1229 Rancho Cucamonga, CA | Radio volume has a speed sensor so the faster you go, the louder it gets. If your speedo cable is loose and erratic, your radio sound will be erratic also. |
| There is no speedo cable......it is electronic. |
Posts: 3773 Pittsburgh, PA | savage - 2011-09-24 4:54 PM
+1 the whole "dashboard" is electronic and controlled but one big wire harness. (i replaced my speedometer) |
| Ill look at the ipod hookup to see if its right. It sucks that it a new out of crate 2010 Ness Vision #82. I had no problems what so ever with my Jackpot for 2yrs. Problem happened at 75mi. Go figure this will have to wait until Monday. I love this bike and want to enjoy it now. Thanks for the replies. |
Posts: 3773 Pittsburgh, PA | just for the hell of it.... make sure BOTH battery terminals are Tight...... |
Posts: 81 Lynnwood, WA | +1
Posts: 1229 Rancho Cucamonga, CA | Never said a mechanical cable, thought you'd get the point.
I guess the iPod dosn't use a cable either.
The point is, It has nothing to do with the iPod and everything to do with the speedo malfunctioning.
Edited by Nozzledog 2011-09-24 8:17 PM
| checked the terminals before I started thread. I gave the harness a decent jiggle and rode 20 miles with no problems. As for the spedo problems the spedo will set itself when I turn the key on. The spedo will not work at all or the needle will bounce up and down while riding. As long its will start I'm. gonna ride it sans spedo and radio until the shop can get it in.
Posts: 117 Kansas City, MO | ride it and enjoy what you can until the dealer opens |
Posts: 2118 Pitt Meadows, BC Canada | Yah - you want to 'ride it' or 'listen to it'? Minor crap - and fixable some other time. JUST ENJOY !
Posts: 3006 San Antonio, TX | Use the set button to and change the setting that adjusts the radio volume per the speed you are going to OFF. I think it is called Auto Volume.
That should take care of the radio. I do not know about the speedometer issues.
Ride Safe |
| Talked to the wrench he told me its a speed sensor. |
