Tip-overs on Visions
opas ride
Posted 2011-09-22 4:14 PM (#97390)
Subject: Tip-overs on Visions
Thanks again today to the Victory engineers that designed the front and rear tip-overs on the Vision..This is the second time I have dumped my new 2011. I have a short inseam of just barely 29" which makes for a challenge at times..Both times I was at a stand still and could not keep bike up-right..Mostly because of my not paying close attention to where I pulled off road...Bought new Vision 8-ball seat today which is 1' lower than stock, and am told this will help...I have to give up heated seat, but don't use it anyway....Rear shock is also an option but costs a lot more money and on Michigan roads I want the higher shock travel....I also burned the right calf of my leg on the right exhaust the other day and the lower seat position should help this issue also as my leg will not be as close to the heat shield. Have sat on a Vision with the lower seat and it does make a big difference for me....BTW I am almost 72 and not a strong as I used to be......Isn't that what Toby Keith sings about !!
dan camarco
Posted 2011-09-22 5:04 PM (#97398 - in reply to #97390)
Subject: Re: Tip-overs on Visions
Lumber Bridge, NC United States
time for a trike opa
okie vision
Posted 2011-09-22 9:31 PM (#97413 - in reply to #97398)
Broken Arrow, OK
dan camarco - 2011-09-22 5:04 PM
+1
not worth serious injury. trike it and ride!
DannyB
Posted 2011-09-22 10:54 PM (#97420 - in reply to #97390)
2 mi from Jim Beam n KY
Trike ????? OH HELL NO!!!!!!!!!!!!!!!!!
David, I'm assuming this is your first heavy weight. It will take saddle time to get used to it. I've barely got a 28 inch inseam, so I'm familiar with your inconvenience. With a good set of motorcycle boots, with 1 inch heels and 1/2 to 3/4 inch thick soles, you should be good to go. Work on you slow speed skills. Age and health should dictate going trike, not inseam.
bigfoot
Posted 2011-09-22 11:21 PM (#97421 - in reply to #97390)
Akron Ohio area
Burned my leg too.
No more shorts.
My cousin is 80 and still riding his Goldwing.
Denny Ray
Posted 2011-09-23 1:49 AM (#97426 - in reply to #97421)
Lacey, WA United States
Short inseam here also. Had my Vision lowered at Arlen Ness's store in Dublin last year. What a difference! It's only an inch but makes it so much easier to plant the feet firmly on the ground. I ride with my wife as passenger most of the time and the lowering was the best thing I have done with my Vision. However, sometimes if I had to park in a spot where the slope of the parking area inclined up from the left side of the Vision I could not get the kickstand down. I would have to drive around the parking lot to find a spot to stop. (A royal pain in the arse). I purchased a lower kickstand from HMD and that made parking my Vision the way it should be.
Before this "upgrade" my Vision was the best motorcycle I ever owned, With the Lowering and the HMD kickstand it is now the better of the best - of the best. Thank you Arlen Ness and HMD!!!!
Denny
opas ride
Posted 2011-09-23 10:58 AM (#97456 - in reply to #97390)
Thanks for the replys..After reviewing the incident in my mind yesterday, Denny Ray hit the nail on the head..I was trying to put down the kickstand at road side to look at map. The slope of the road was higher than the right side of bike and I tried to lower kick-stand which hit pavement. So as I tried to angle bike to get stand down, over she went..No damage, just ego....Had to find some passers-by to help pick it up...I may have over reacted when I ordered the 8-ball seat, as I don't have $300 bucks right now..But the 1" lower seat should give me some mental confidence and I do like the idea of having both feet on ground at stops...BTW I did add higher heels and soles to my boots which really work great......
Edited by opas ride 2011-09-23 10:59 AM
pollolittle
Posted 2011-09-23 12:57 PM (#97467 - in reply to #97390)
Brighton, TN
Did he just say high heels? Good to see your gettng it figured out, and good to see trike time not here yet.
opas ride
Posted 2011-09-23 1:11 PM (#97471 - in reply to #97390)
Pollolittle... As some have said on the VMC board, the Vision is a "Fag Wagon" so why not ride with high heels????Just kidding of course and your right on trike time is not for me.......Yet.....
Edited by opas ride 2011-09-23 1:12 PM
pollolittle
Posted 2011-09-23 3:28 PM (#97481 - in reply to #97390)
Brighton, TN
Shall we all dress in drag just cause! I know a guy that could help in this department, he does it for a living. The best part is that I can put my fag wagon in my showcase when I'm done riding it as a piece of motorcycle art and history. How many others can do that? Not only that, maybe just because it has too much sex appeal over other styles is what makes us so attracted to it, sensually, instead of rising my testosterone levels.
Mr Sug
Posted 2011-09-24 1:31 AM (#97517 - in reply to #97390)
Kansas City, MO
just keep on riding!!!!
TRELL
Posted 2011-09-24 8:51 AM (#97532 - in reply to #97390)
OK thats my problem 5'7'' 29 inseam need to lower the vision (I LOVE THE BIKE). Some here tell horror story on lower it. Lowered the GL1800 1" (cost $585)things were much better with it after that. Just 1'' and i think i'd be alright but do not know much abiut shock system on this bike..
bob5219
Posted 2011-09-24 10:24 AM (#97537 - in reply to #97390)
to the person who calls Vision a fag wagon, tell that to Sonny Barger or the guy who has the different paint scheme.
