| I am a new Vision owner and have a couple question regarding a couple things I read in the owners manual.
1. The owners manual shows and explains how to change out the ipod/aux leads. Should there have been a second lead for the ipod supplied with the bike?
2. The power points in the ipod compartment & trunk. Do I need to purchase some power lead, and where might I get it?
3. Has anyone else had a bad dash panel rattle and how did the dealer or you fix it?
Thanks in advance...... T |
Posts: 74 Puyallup, Washington | Teach - 2008-04-28 5:54 PM I am a new Vision owner and have a couple question regarding a couple things I read in the owners manual. 1. The owners manual shows and explains how to change out the ipod/aux leads. Should there have been a second lead for the ipod supplied with the bike? 2. The power points in the ipod compartment & trunk. Do I need to purchase some power lead, and where might I get it? 3. Has anyone else had a bad dash panel rattle and how did the dealer or you fix it? Thanks in advance...... T Welcome to the ranks of Vision owners. We're a pretty happy bunch here and the more the merrier. You will have to buy the ipod cable from your dealer. I think its cost 39.95. You can get adapters for the power outlets in the the glove box and trunk here: http://www.cyclegadgets.com/Products/product.asp?Item=PLUG and many other sites on the net. If you can't wait (like me), you can probably find the same adapters at your local BMW motorcycle dealer. That's where I purchased mine and it works great. Sorry about the rattle, but, I can't help you there. Safe riding. Wayne |
Posts: 83 Lexington, North Carolina | Welcome Teach and congrats on the new ride. You have to purchase the ipod cable seperately and an adapter for the for the power supply. The power supply that is there is the BMW style. There have been several posts here before with a link for adapters. Hadn't had the rattle but it does seem like someones mentioned it before? |
| Thanks guys I really appreciate the replies |
Posts: 1324 So Cal | If its an apple ipod the $39.95 cable is all you need, it also supplies power to the ipod.
The dash rattle. If you grab the chrome bezel around the speedo and pull rearward it will pop off. Its retained by four metal spring clips.
Where the bezel meets the brushed dash panel, I applied a strip of black elec. tape to the bezel half and then re-installed. It was more of a buzzing type rattle on accell. The tape was just enough to insulate the two panels and keep them from vibrating.
I also had a heavier rattle over rough roads that turned out to be the rear plug wire banging against the left body panel. I used a plastic tie strap LOOSELY around the wire to a harness under the body panel. Just enough to keep it away from the panel. Too tight and the EMF from the wire may affect the harness. |
Posts: 8144 New Bohemia, VA | Whew! Thanks guys, I thought the rattle was in my head. |
Posts: 562 SC, Bluffton | My dealership put foam tape on the bezel @ my 2,500 mile service. No charge, and it worked.
| I am currently running my ipod from the original connector. Does anyone know the advantages of the ipod harness? Can I change songs etc from the console? |
Posts: 600 Linwood, MI | jwbnh - 2008-09-22 12:33 PM
The iPod will cycle on/off with the bike, no need to do it by hand. The bike's charging system will also charge the iPod. You can cycle through songs using the Tuning button and you can access playlists using the radio station preset buttons. |
| thanks rebel that is exactly the info I was hoping for |
Posts: 203 Rapid City, SD | What model and generation I-Pod is everyone using? My new Vision will have the cable installed and I would like input from everyone on which I-Pod they are currently using. If I had my choice I would prefer the new generation I-Pod Touch. I already am aware of the Hard Drive incompatibility.
Posts: 3006 San Antonio, TX | If you are cheep do what I did. I bought an 4GB iPod Nano from a pawn shop. It was a 3 Generation Nano but they had 2nd Generation Nano's too. It was priced at $90. I tested it in the store and played some songs on it. The controls worked just fine.
I offered him $50 and we settled on $60 for a 3rd Gen 4GB Nano. It is all loaded up with my music and works just fine.
iTunes is free and the Nano I bought came with a USB cable.
Ride Safe, |
