Posts: 102 Cedar, Michigan | So what are the options for both front and rear, seems slim to none? |
Posts: 741 Central New York | Kruzer Kaddy.
Posts: 785 Mt. Vernon, WASH. | Pick up one from the accesories display @ the dealers, you change the lower half of the left side controls clamp on the bars and it uses a threaded ball that the holder clamps to, took me about 7 minutes from 'let's see about this' to 'hey! it'll hold a pretty big cold drink cup'. Don't know what your passenger would do with their drink-but they pretty much do have both hands free all the time.
You'll need a metric allen wrench set. |
Posts: 102 Cedar, Michigan | glighto11 - 2011-06-08 9:15 PM
Kruzer Kaddy.
Yea, I had that on my past bikes. There seems to be no application for the Vision, am I missing something? |
Posts: 1359 New Bohemia, Va | ...mine...
 (CIMG0187.jpg)
Posts: 965 New York State | I have the Kruzer Kaddy on my right hand side of the handle bars chrome looks great |
Posts: 37 Southern Indiana | I have the ram ball mount in the hole on the brake handle with thier cup holder and love it will hold any drink you want
Posts: 1117 Northeast Ohio | Trekwolf164 - 2011-06-08 8:44 PM
+1 but on the left. |
Posts: 3006 San Antonio, TX | ScoreBo - 2011-06-08 9:07 PM
+1 but on the left.
+2 One on each side!
Edited by radioteacher 2011-06-08 9:59 PM
 (TwoKruserKaddys.jpg)
Posts: 142 elgin mn | my Kruzer Kaddy is on left handlebar,have seen Passenger on The Right grab handle.. |
Posts: 1229 Rancho Cucamonga, CA | Kruzer Kaddy- you need to buy longer bolts though.
 (2011-01-31 13.50.21_edit0.jpg)
 (2011-02-19 13.02.03a.jpg)
2011-01-31 13.50.21_edit0.jpg (57KB - 3 downloads)
2011-02-19 13.02.03a.jpg (82KB - 2 downloads)
Posts: 741 Central New York | I thought that the Bar Clamp that came with my KK was ugly and mounting on the control cylinders was too in-my-face. I used the piece of flat stock they give you and drilled and tapped my handle bar about halfway to the tree, on the outside. Works great.
Posts: 37 Southern Indiana | This is the set up I'm running
Edited by RiverRat 2011-06-09 8:20 AM
Posts: 669 Peachtree City, GA | ScoreBo - 2011-06-08 10:07 PM
+1 but on the left.
+1 on each Vision on the left.
Posts: 160 Camas Washington | Every morning I ride into work with a large 32 oz cup of java (plastic starbucks clear cup). I use the Victory holder with the ram ball on the left side. Works great. The key is the have the mount sticking straight up with a little lean to the back. This way the cup will lean up against the arm and sway around. The holder has 2 hooks which I take a large rubber band to hold in place until I get to work. If i want to drink while riding it requires a smaller cup with out the rubber band holding it in place. Smaller cup the wind will not effect it in the holder. |
Posts: 102 Cedar, Michigan | So you guys that have a Ram Ball mounted toward the outside of the clutch and brake reservoirs must have a different housing than I do. There is no hole tapped on my 2008 Vision Premium Tour.
 (DSC04684.JPG)
 (DSC04685.JPG)
Posts: 1359 New Bohemia, Va | Mattchristiani - 2011-06-09 12:12 PM
that's true, you can do your own though as some has done, or buy newer ones with the holes. |
Posts: 785 Mt. Vernon, WASH. | The replacement bottom clamp half that came with my VICTORY holder has two pre tapped holes, one mounts theball up the other points it aft |
Posts: 2118 Pitt Meadows, BC Canada | I use the reliable Co-Pilot Caddy. She doesn't have much other stuff to do, and she is welcome to sip from my cup while she holds it for me. When I need a sip, she passes me the straw.
BONUS: Auto refills whenever I stop - best Drinkholder EVER !
Posts: 669 Peachtree City, GA | Correct - 08 did not have them... 09 and up do.
Posts: 175 Hinton, Iowa | Try this Kruser Kaddy mount made just for the Vision.
Hey Everyone....just wanted to give you a heads up.We are an official Kruzer Kaddy Dealer.
I stock the Vision Clutch Mount for the Kruzer Kaddy Cup Holders.
If you have been looking for one...you can get them here.
http://www.noemtz.com/kruzerkaddy.htm
Thanks!
NOEMTZ |
Posts: 199 Salt Lake City | airguy - 2011-06-09 3:05 PM
yep, yep, yep - thats the one I have. An excellent piece of work. |
Posts: 277 Apopka, FL | I use the mount I purchased from Noemtz too. It works well. Buy it, the price is right. |
Posts: 277 Apopka, FL | Rear passenger cupholder = Victory armrests... they have the cupholder under the right arm that swings out.
Posts: 23 Stony Mountain, MB Canada | I just drilled and tapped a hole on the forward side on the left side of the solid handlebars of my 2009 and then screwed the mounting bolt in for the Kruzer Kaddy and mounted the cup holder right onto that. |
Posts: 1229 Rancho Cucamonga, CA | glighto11 - 2011-06-09 5:57 AM
I thought that the Bar Clamp that came with my KK was ugly and mounting on the control cylinders was too in-my-face. I used the piece of flat stock they give you and drilled and tapped my handle bar about Halfway ay to the tree, on the outside. Works great.
Any pics?
Posts: 1229 Rancho Cucamonga, CA | nealwirgau - 2011-06-10 11:02 AM
Any pics? |
Posts: 23 Stony Mountain, MB Canada | I tried putting some pictures up on the Sirius thread, but I am not sure if they will be up there or not. |
Posts: 492 Indianapolis, IN | donetracey - 2011-06-09 1:53 PM I use the reliable Co-Pilot Caddy. She doesn't have much other stuff to do, and she is welcome to sip from my cup while she holds it for me. When I need a sip, she passes me the straw. BONUS: Auto refills whenever I stop - best Drinkholder EVER ! +1 Don, even though I also have a bar mounted cup holder on my bike as well. There's a bonus with your passenger cup holder to boot. Since she's back there the top of her leg makes a great arm rest for the rider when he needs to rest one or the other. There are other benefits to the "rear passenger cup holder", but we'll leave that to everybody's imagination. ;-) |
Posts: 785 Mt. Vernon, WASH. | A former 'passenger' friend of mine used to wrap one or both legs around my waist so her calf made a dandy arm rest too. |
Posts: 4 Maricopa, Arizona | I actually used one of those Aluminum Drink Bottles that are so popular these days. I cut it off, smoothed the cut edge, drilled some holes in the bottom for drainage (rain and spills), and I mounted it with a rubber guarded electrical cable strap with a machine screw, lock-nut, and nylon bushing. I placed it between the clutch reservoir and the handlebars. It's sprayed Gloss Black. Since I waited till I could find a wide bottle to use, it takes up to a 32 oz cup in it. I've been riding with it for about 5000 miles with not slippage, spillage, or other mishaps. Total cost to make $4.00 and about an hour to build for those of us who are semi-handy. If anyone is interested, I can post some pictures. |
Posts: 741 Central New York | Sorry. I Missed this request for pics. I'll try to get something later this morning.
Posts: 102 Cedar, Michigan | So after much pondering I decided to go with the Ram Ball set up. It is not very pretty but damn it works great.
 (DSC04691.JPG)
 (DSC04692.JPG)
 (DSC04694.JPG)
Posts: 741 Central New York | Hope these help, Blackberry camera can only do so much.
 (fromseat.jpg)
 (Deviceholder.jpg)
 (fromgrip.jpg)
 (righttpleft.jpg)
 (fromwindshield.jpg)
| Does anyone know how large of a cup that ram ball setup from victory will hold? |
Posts: 492 Indianapolis, IN | G187 Welcome to the forum. We are able to put a standard coffee mug in ours, by this I mean the standard size mug that typically has logos and pictures on them that we give as a gift. Also it will work very well with the standard 32oz Styrofoam soft drink cup that most convenience/gas stations have at the soda dispenser. The 32oz fits snug and still balances well, not tippy. PS One other thing that's great about the Ram mount is that it's quick and easy to remove the cup holder and the ball mount can be used for any other accessory holder that Ram makes, cell phone, gps, mp3 player, map holder..............pistol holster....... LAPTOP!.......... just kidding ;-) They are somewhat universal in this way.
Edited by hoosiervic 2011-06-19 9:35 AM
 (Cup holder 1.jpg)
 (cup holder 2.jpg)
 (Cup holder 3.jpg)
Cup holder 1.jpg (99KB - 2 downloads)
cup holder 2.jpg (97KB - 0 downloads)
Cup holder 3.jpg (80KB - 0 downloads)
Posts: 102 Cedar, Michigan | G187 - 2011-06-19 8:48 AM
I wanted to install a cup holder on my bike so I could put a to-go cup from say a fast food place. The ram Ball cup holder will hold a very large cup in that sense. I put 44 oz. Sam's Club styro cups in it yesterday will no issue. |
| thanks guys, you hit on the exact reason I was considering the ram ball cupholder over the kuryakyn I have now (which also works pretty good all things considered)
thanks |
Posts: 599 New Mexico | hoosiervic - 2011-06-19 8:27 AM
PS One other thing that's great about the Ram mount is that it's quick and easy to remove the cup holder and the ball mount can be used for any other accessory holder that Ram makes, cell phone, gps, mp3 player, map holder..............pistol holster....... ?LAPTOP!.......... just kidding ;-) ? They are somewhat universal in this way.
Looks like you have it mounted into the mirror bolt hole on the front brake master cylinder. Did it come with that mounting, or was it special.
Posts: 66 Harrisburg, PA | G187 - 2011-06-19 7:48 AM
32oz plastic cup from any fast food or gas station. I prefer the McD's foam cup. it keeps the drink cold
Posts: 492 Indianapolis, IN | Boots - 2011-07-02 1:43 PM hoosiervic - 2011-06-19 8:27 AM PS One other thing that's great about the Ram mount is that it's quick and easy to remove the cup holder and the ball mount can be used for any other accessory holder that Ram makes, cell phone, gps, mp3 player, map holder..............pistol holster....... ?LAPTOP!.......... just kidding ;-) ? They are somewhat universal in this way. Looks like you have it mounted into the mirror bolt hole on the front brake master cylinder. Did it come with that mounting, or was it special. I believe with the 2010's and later the threaded hols for mirror mounting are factory. It is very easy to drill and tap the holes yourself if your bike doesn't have them. Ram offers the 1 inch ball mounts with both metric and standard threads. The ball mount sold by victory is metric, I believe 10mmx1.25. |
Posts: 599 New Mexico | Just installed this Chubby Cups Jr. Cost $40, seems solid and well built, but time will tell whether it holds up.
 (Cup1.JPG)
 (Cup2.JPG)
 (Cup3.JPG)
 (Cup4.JPG)
| what??? I don't even get my nane that I help at lest WERE'S THE LOVE |
| Does anyone know the purpose of the two extruded hook-like things on the RAM cup holder? |
