Easy Cluch for Vision??
Mr Sug
Posted 2011-06-06 10:55 PM (#88182)
Subject: Easy Cluch for Vision??
Kansas City, MO
Has anybody ran across one for our bikes yet? Had one on my Ultra and my King - that are great
Mr Sug
Posted 2011-06-06 10:56 PM (#88183 - in reply to #88182)
Subject: Re: Easy Cluch for Vision??
Kansas City, MO
That was clutch
JustBob
Posted 2011-06-08 10:57 PM (#88404 - in reply to #88182)
The thing is; the Vision has a hydtraulic clutch, why do you need an ez clucth? if it is hard to pull, you need to have someone look at it.
Lotzafun
Posted 2011-06-09 7:05 AM (#88406 - in reply to #88182)
Rockford, IL
You can switch over to a Cross Country clutch.
Here are a couple of posts over at thevmc that should get you going in some type of direction on this....
http://forums.thevmc.com/bb/forums/thread-view.asp?tid=90421&posts=...
http://forums.thevmc.com/bb/forums/thread-view.asp?tid=90486&posts=...
Cap'n Nemo
Posted 2011-06-09 7:54 AM (#88408 - in reply to #88182)
New Bohemia, Va
...or 8-ball clutch, cable type. There was a buzz about the ez clutch some time back, so you may be able to search the forum for further information, also, on theVMC.
Plumley
Posted 2011-06-09 8:50 AM (#88418 - in reply to #88182)
Subject: RE: Easy Cluch for Vision??
Alberta, Canada
I though my Vision already had an easy clutch!!! It might be cheaper for you to go buy yourself a set of wrist builders!! lol
jeffmack
Posted 2011-06-09 10:54 AM (#88422 - in reply to #88404)
JustBob - 2011-06-08 10:57 PM
because he wants one
Posted 2011-06-09 11:13 AM (#88426 - in reply to #88182)
Compared to the HD CVO my brother used to ride the Vision Hydraulic Clutch is no better than a cable clutch. The HD CVO Hydraulic Clutch is very smooth with a shorter and lighter pull.
Ride Safe
Edited by radioteacher 2011-06-09 11:14 AM
Posted 2011-06-09 11:30 AM (#88431 - in reply to #88182)
I don't under stand. If you put on a cable now it be comes easier to pull ??
Mr Sug
Posted 2011-06-09 10:32 PM (#88497 - in reply to #88182)
Kansas City, MO
ez clutch uses mechanical advantage - other hydralic clutchs I have noticed are a little easier - I will have the dealer look at it. Like most things, I am sure it is just me
Cap'n Nemo
Posted 2011-06-10 7:34 AM (#88509 - in reply to #88182)
New Bohemia, Va
I might need to go there as well. I find that the Vision clutch is easy to pull, but I my left hand is losing strength. Making it even easier to disengage would prolong my riding days. It shouldn't baffle so many people about some request people make. I'd rather have an ez clutch any day over a $400 wind deflector...
Posted 2011-06-10 6:05 PM (#88554 - in reply to #88182)
Try this....go to dealer and find an 8-Ball Vision and a Vision Tour. Check the feel of the clutch on each bike and tell me if either clutch has less weight in its pull or shorter length of the pull.
The 8-Ball has a cable clutch and the Tour has a hydraulic clutch.
I can not tell the difference.....and my point is that you should!
For goodness sakes I do not have mechanical cable brakes...If I did think how hard that would be to stop this heavy bike. So for the brakes the pull is shorter and lighter.....but there is no difference in the clutch between the cable and the hydraulic models that I notice.
What I did notice is that my brothers HD CVO with a hydraulic clutch is a shorter pull and a lighter pull.
Ride Safe
Posted 2011-06-10 7:02 PM (#88557 - in reply to #88182)
Say can some one post a web site for this ez pull
TKS
