Posts: 32 shelbyville tennessee | I just noticed my top truck lights are not working, any one have any ideas as to what i need to check for to get them working?
I forgot to add that i installed the factory xm radio today, i dont think that would have anything to do with that lights but just wanted to add that.
Edited by misterclean911 2008-04-22 9:04 PM
Posts: 1324 So Cal | You might try accessing the harness thruogh the plate at the bottom of the trunk. Are you sure you didnt pinch a wire and blow a fuse when installing the seat? |
Posts: 32 shelbyville tennessee | I did take the seat back off and check the wires, ever thing looks ok , i also checked all fuses and relays and there all good, I had took the bike to the dealer the other day , they had to replace the rear brake switch i wonder if they did something to it there. |
Posts: 8144 New Bohemia, VA | misterclean911 - 2008-04-22 11:16 PM I did take the seat back off and check the wires, ever thing looks ok , i also checked all fuses and relays and there all good, I had took the bike to the dealer the other day , they had to replace the rear brake switch i wonder if they did something to it there. I've noticed that the wires are a little tight, especially since I put the rack on. Maybe some could have pulled apart around there.
Edited by varyder 2008-04-24 9:28 AM
| when i put my trunk on ,the lights didnt work either.the bulbs were just loose. |
Posts: 32 shelbyville tennessee | I found the problem, it was in the wiring harnes that runs from the top trunk lid down in the bottom part, a wire had some how got broken it was a easy fix after i found the location. |
