Posts: 880 Orlando, FL | I'm looking to add a switch using the top left empty switch space. Checked with the dealer and they want $40 for the switch which seems like highway robbery. Does anyone know where a substitue switch can be found?
I'd actually like 2. One a rocker switch and the other momentary on push switch.
THANKS |
Posts: 366 Albuquerque, NM | If you know the dimensions of the switch cutout, this ebay vendor may stock it. They also carry momentary switches. Judging from the low price, they may not be weather resistant.
http://stores.ebay.com/GAMA-Electronics-Inc?_trksid=p4340.l2563 |
Posts: 741 Central New York | $40 may seem steep, maybe it is, but I would caution you to choose your substitute wisely. A switch not designed for the application could fill with water and run your battery down when you least expect it. Most cheap switches will just let water in and run right through, leaving the only ill effect, corrosion. But if it lets water in and retains it, it will complete a circuit. The Victory switch is not water proof, but it is pretty much corrosion proof. |
Posts: 64 St. Louis, MO United States | I got a near identical looking switch from Autozone when I added accent LED's. I just took in one of the existing switches and they had one on the shelf that looks almost identical. Did this two years ago so do not have the part number but it may be worth a shot. glighto11 makes a good point about waterproof. My LED's are on switched pwer and they are fused. |
Posts: 742 North Orange County CA | There is a listing for replacement switches in the Vision-riders.com Parts Listing , link below.
http://www.Vision-riders.com/parts.asp
I have not personally tried them, but there are a couple of items that appear to be direct replacements in a couple of configurations. Perhaps the person who added them to the list will chime in.
| I only paid $19 buck for a extra 4 way flasher switch from my dealer |
Posts: 880 Orlando, FL | Thanks to all, esp Tarpits for the Vision Parts list~! I had not seen that. Also in searching the site found out that according to one user our switches are made by Otto Engineering and are the waterproof K1 switch. I'm trying to find out if they are available on a retail level. |
Posts: 1632 Jasper, MO | john frey - 2011-05-09 5:27 PM
Same here, except I went with an extra heated grip switch so I would have the option of controlling two different circuits. $19 plus tax from the dealer. It's made by Otto and is weatherproof.
Your dealer needs to check his pricing again. Sounds like he was looking at TWO switches for $40.
Ronnie |
| If they don't go to the computer and look you know there guessing and they would rather be hi then low. I have one dealer 4 miles away and another 34 miles away. I call the shop that is far away cause he treats me right. Not to say the other shop wouldn't. 40 bucks doesn't sound like he even knows what switches are.
Posts: 880 Orlando, FL | Thanks to everyone. I will try another dealer. This board is the best, cause you guys are great. Thanks again to all!! |
