| you really have to shift the tranny just right..or it's a clunky SOB.....if your technique is just right the tranny just "sincks" into gear..quiet as any I have ever owned. I havent figgered it out just yet..........But I will  |
Posts: 72 Eyota, MN | Are you pulling in the clutch? Ha! Ha! |
| Clutch? ...............What clutch?  |
Posts: 2027 Brighton, TN | I'm a little different, I stomp on mine to get it into first, just so it will go Ka-Thunk! Maybe I just like the raw sound of metal colliding and the jolt in the seat from the gears getting to know each other. It's a little primal, but I LOVE IT!
Songfan, said he knew how to do it, I don't remember which thread though. |
Posts: 82 Northwest of you | You mean, the reason it sounds like metal parts are locking into place...........is because there are metal parts, locking into place???????????? |
Posts: 2027 Brighton, TN | Your right, what I meant to say was, "I'm a little different, I stomp on mine to get it into first, just so it will go Ka-Thunk! Maybe I just like the raw sound of metal colliding and the jolt in the seat from the gears getting to know each other. It's a little primal, but I LOVE IT! "
norwor218 - no idea what the question is, try me again, maybe I understand better twice. |
Posts: 1484 LaPorte,Tx. | Sometimes you can do this. Try pulling in the clutch about 15-20 seconds prior to shifting into 1st gear. It seams to reduce the "Ka-Thunk". |
Posts: 238 SF Bay Area | What clunk? The Vision?
I have a '99 V92C... now that bike has a clunk! |
Posts: 257 Under the Rule of Jedi - Masshole | An FYI...
Pressing hard on the shift lever will place undo wear and tear on the shift forks.
All that is need is a gentle press.
Also it seems a lighter press does reduce the clunk. |
Posts: 496 Scottsdale AZ | pollolittle - 2008-04-20 9:05 AM
You are definitely a "little different"- livin in "nowhere" Tenn with chickins and a embroidery machine that apparently also goes "clunk" - Maybe you should change you name from poloolpoop to clunk - You'r kids could call you "clunk" instead of chikinDAD- sorry- maybe it is Ka-Thunk!! LOL |
| Well I don't own a Vision yet but I do own a '99.
Also make sure your RPMs are all the way down before shifting into first. I have found myself shifting before she is at idle causing pressure across the system.
