Posts: 14 Dublin, Ohio | I took my Vision back to stock and I can't figure out what this orange plug goes to. I don't remember unplugging it when I removed the PCV. It's on the left side above the ignition coil. Everything seems to be running ok.
Thanks for any help. Bugging the crap outta me.
 (orangeplug.jpg)
Posts: 741 Central New York | Looks like a lighted badge light plug. |
Posts: 14 Dublin, Ohio | Good thinking, but I ran out to check and both badges light up. Wonder what else it might be? |
Posts: 142 elgin mn | I checked My stock 08 not plugged in to any thing Fyi!!!!!!!!! |
Posts: 14 Dublin, Ohio | I checked the wire colors. Purple/pink is one and the other is blue. |
Posts: 14 Dublin, Ohio | Woohoo! I can go to bed now!
Thanks! |
Posts: 111 Salina, KS | It goes to nothing....mine has the same plug, in the same location, just extending from the harness. I was surprised to see it the first time I put my VFCIII on. It should have a termination plug on it so as to not compromise the harness wiring due to corrosion I would think. |
Posts: 307 Columbia, SC | Not connected to anything on my 09 premium. |
Posts: 741 Central New York | I only connector I can find with that color combination goes to a "purge valve". I never heard of a purge valve. |
Posts: 14 Dublin, Ohio | Maybe it's a California bike thing? |
Posts: 965 New York State | Is that not the connection for the Victory Coffee machine ?
Posts: 669 Peachtree City, GA | That is for the optional AC unit under development. |
