Posts: 94 milwaukee wisconsin | does anyone else get the smell of gas fumes at a stop light i have a 09 vv and latley im getting gas fumes at stop lights ?? and cant see any leaks |
Posts: 37 Southern Indiana | Do you have the new fuel cap or the one that come with the bike.
Posts: 94 milwaukee wisconsin | it is the stock fuel cap that came with the bike |
| That would be the problem. The original caps didn't seal properly. Your dealer should have one of the replacement caps. |
Posts: 94 milwaukee wisconsin | is this a recall or just a warranty issue ?? |
Posts: 732 Western WA | I believe it is a warranty issue when the cap fails.
I've had the cap replaced, as well as the tanks themselves because of the really thin filler neck on the 2008s. All under warranty,
Last summer I had the smell of gas again - usually after a fill up. Found out that there was a gap forming around the bottom of the filler neck so that when I occasionally over-filled, the gas would leak around the filler neck instead of going into the overflow tube that drains beneath the bike. Fixed it with two things: 1. A bead of silicone around the base of the neck. 2. To pay attention and quit over - filling. |
Posts: 94 milwaukee wisconsin | yep called randys cycle in ill great guy he did not have a new gas cap in stock but i will have it next week under warranty also told me about the gap around the filler neck will pull it aparts tomarrow and put some seamsealer around it since the dealer is about 2 hours away !! |
| Jay says my filler neck is bent and the extended warranty is replacing the whole fuel tank. Of course it's on back order till May 5th. The right leg of my pants got wet with gas the last 2 fill ups that got me to have Jay check it out. |
