Posts: 28 Basehor, Ks. | Anybody out there know where I can get a chrome front fender tip that fits the Vision? Paints wearing off from those nasty gravel and road chips. Thanks! |
Posts: 38 Prince George, BC, Canada | The only one I could find is the one that Victory sells. No aftermarket available at time of purchase and I don't think you will see one in the near future.
Cheers! |
Posts: 1359 New Bohemia, Va | not that the front fender isn't adequate, I'd like to see some changes made for it though. I've fallen prey to the broken rear half because of the mudflap. I thought it was from the weight, but I think it happened from the mudflap pushing up when I went over a speed bump or something. It's necessary to have a lower flap to keep the gunk out of the front bottom, but the rear piece is brittle. The rear would look good to be the same composite and color as the front, and the front would look great with a chrome piece or grill.
There are aftermarketeers on here that are paying attention, just wonder if they can expand their line.
Edited by Cap'n Nemo 2011-03-29 3:44 PM
| I saw one on ebay yesterday. You can find a car body shop and they can weld plastic. |
Posts: 3006 San Antonio, TX | Could you take some after market door trim chrome and wrap the edge of the bumper to fix it? |
| Cap'n Nemo - 2011-03-29 3:43 PM not that the front fender isn't adequate, I'd like to see some changes made for it though. I've fallen prey to the broken rear half because of the mudflap. I thought it was from the weight, but I think it happened from the mudflap pushing up when I went over a speed bump or something. It's necessary to have a lower flap to keep the gunk out of the front bottom, but the rear piece is brittle. The rear would look good to be the same composite and color as the front, and the front would look great with a chrome piece or grill. There are aftermarketeers on here that are paying attention, just wonder if they can expand their line. I believe that HMD has a replacement rear half front fender made out of fiberglass although I think you may have to use their replacement front front half fender to use it. Richard
Posts: 1359 New Bohemia, Va | I've fixed my rear half, but I need to look around again, I believe I've seen what you are talking about. |
