| well, its something i thought I'd never do, but I am going to have to go darkside soon. reason is I will be riding form Georgia to Alaska next year..a round trip of 14000 miles, running on gravel, mud, and who knows what else. Dont want to do a mid ride tire change, and want a little security against the gravel/tire punctures/rips. The Alcan and Dempster highways are hell on tires.
Anyway, I have come to the conclusion after much reading I will have to try the darkside for this trip, but also dont want to do it a week before my trip. Will need a new rear in a few months. I go into this assuming I will go back to the E3's when I get back, but if the darkside sways me into sticking with it so be it.
1. Did a Victory shop mount your tire?
2. Anyone darksiders in North Georgia or SW NC or E Tenn? if so where did you get yours mounted.
3. What tire and size did you go with? and why?
thanks guys, I hope this doesn't turn into a debate, just some intel.
JMACK |
Posts: 24 Hanover, Md | Jeff, I run a Bridgestone Potenza G019 Grid 195/55-16 on my Vision, and I keep about 33lbs of air pressure in it. I've had it for about 1500 miles or so, and I am very happy with it. I chose it because it had very good traction numbers, and a friend of mine runs one on his Goldwing. He has about 20,000 miles on it and it still looks and handles great. I planned on going darkside with the Vision from the day I bought it. I had a General Altimax on my Kawi Vulcan, before the Vision. I had probably 15,000 miles on it when I traded it in for the Vision. I loved it. Good luck. |
| From what I have read the darksiders are running 195/55-16 witch is the same as a stock dunlop3
http://mcdarksiders.forumotion.com/
Due a search here and you'll find out more. Every thing I have read once you go dark you never go back.
http://www.vision-riders.com/bb/search/query.asp?fid=0&action=searc... |
Posts: 161 Tampa, Fl United States | jeffmack - 2011-03-22 6:30 PM
JMACK
1. Victory shop mounted the tire for me
2. I'm in Florida & due to rains,gravel,oil,sand & traction problems thats why i went to the Darkside
3. Bridgestone Potenza G019 Grid 195/55/16 as well,paid $80
PS-once you've tried you wont go back,u wait n see!!!
Edited by turbobuick 2011-03-22 6:27 PM
Posts: 215 orrick, mo | I had a local tire shop mount just becuz of covenience. A mile from my home and closest bike shop 25.
I'm running a 195/55/16 yoko now but I had a potenza on before and liked it a lot. I'm also using dyna beads
so I don't have to worry about ugly wheel weights. I'm running 36psi. The higher tire helps break the side
wall in quicker. The only draw back that I can see in the darkside is until the tire is really broken in good is that uneven surfaces can move you around at slower speeds. Not sure how it would do in the mud but they are fine in the gravel. I choose that size becuz of this forum and that size of tire can be found in about any tire shop. I have read of people running run flat tires also. I don't if that is something you would consider or not but being out in the middle of BFE it might work to limp you to the next tire shop. either way ride safe and
have a great trip. Once you get used to the darkside it'll be hard to go back to the mt.  |
| good deal, Potenza seems like the way to go. thanks for the info. I will call my local shop and see if they will mount. I am starting to worry that i wont go back to the MT!! |
Posts: 466 Grand Cane, LA | I also run the Potenza G019 in the 195/55r16. Got about 1000 miles on mine and run the pressure at 34-35psi. It does take a little getting use to with the slow speed and road grooves but you will love how it corners. And you can sit at a redlight and notice that you barely have to hold the bike as much waiting for the light to change. A definite plus when riding a lot in town. The highway cruising is definitely smoother. Once you go dark, you'll probably won't go back. Oh, and I had the local 4-wheeler shop mount my tire. They used the Yamaha tire mounting spray lube and had no problem getting the bead to seat like some have had.
Edited by atvtinker 2011-03-22 9:59 PM
Posts: 1229 Rancho Cucamonga, CA | What about the 'Run Flat' tires? I will be heading up to Alaska as well and plan to go dark for the same reasons. I have heard that running 'Run Flats' makes it hard to tell if the tire loses pressure, but I have a TPMS for that. |
Posts: 395 Moravia, IA | Another Bridgestone Potenza G019 Grid user here.....great tire. I went with the 185/55-16 instead of the 195. I run a hitch and while the 195 does work, the 185 gives me just a bit MORE clearance.
So far Ive got about 24K miles on my rear tire....zero problems. Its wearing nice and even.....and honestly its hardly wearing. Id say after 24K miles its probably 60 to 70 percent. I will change it on general principal likely before it wears out. Alot of that mileage was 2 up and pulling a trailer.
After a few miles getting used to it you will forget its even under there.
Im running mine at 35psi.
Nozzledog - 2011-03-22 10:36 PM
You are correct, alot of people choose NOT to use run flats because they'd like to have a little warning as a tire is going low, which you dont get with a run flat. I think this is completely covered if you have a TPMS, which I have been considering getting.
Tell me a bit about your unit and how you like it.
Edited by aaronrkelly 2011-03-22 11:10 PM
Posts: 1229 Rancho Cucamonga, CA | The Doran has been a great little sensor. I have it mounted in the small compartment inside the saddlebag with the warning light underneath the front right speaker grill completely invisible when it is not flashing.
The Doran sensors send a signal to the main unit every 6 minutes if the pressure has not abruptly changed. Once your tire pressure falls below 12.5% of your set pressure, than the warning lights will blink and an audible alarm goes off (not real loud though). It will blink faster if the pressure drops below 25%. The sensor will also send an immediate signal if the pressure drops more than 2.8psi in 12 seconds. I have mine wired to come on when the bike is turned on, others have it wired to always be on (the power draw is about 30ma). When I turn my bike on, it can take up to 6 minutes to get that first signal (it blinks in a pattern to let you know it's acquiring a signal). Most of that time, I am doing my pre-trip inpection and letting the engine warm up. once the signal is acquired, to check the pressure in my tires, I only have to open my saddlebag and push a button to switch from each tires reading. Mine is set to 41psi for both tires. I know as long as my light is not blinking, that I have at least 35 psi in each tire.
The only downside is, that if your tire loses less than 2.8psi/12sec you will not get a warning until the 6 minute signal is generated. it would be theoretically possible to lose all your air over a 3 min period and not be warned for up to another 3 minutes. Another good reason for a 'Run Flat". |
| Hey Jeff check this out. I think is great. By the way any after market motorcycle shop would mount your tire I'll bet.
You can order on line and its only $14.95
http://www.ride-on.com/
Edited by john frey 2011-03-23 12:44 PM
| Sounds like the darkside is the way to go for you. Keep us posted once you do.
I don't know how the run flat works. Would the TPMS sensor get confused by the material used? Do you know of others that have both working? Just hate to see you spend money and find the TPMS doesn't work under those conditions. |
Posts: 38 NW Jersey | Russe63 - 2011-03-22 7:07 PM
I checked the TireRack site and did a comparo between the Bridgestone Potenza GO19 & the General Altimax and the General has better performance than the Bridgestone AND it is less expensive with a Higher rating. This topic got my curiosity up and if I were to switch to the "DARKSIDE", I believe that the General Altimax would be my choice......... JMHO |
Posts: 395 Moravia, IA | The General Altimax IS a great darkside tire - over on the dark forums its the most widely used. You cant go wrong with it.
I went with the Bridgestone because I could walk into my dealer in town and just buy one. Couldnt do that with the General. |
Posts: 1229 Rancho Cucamonga, CA | Still looking for some info on run-flats. Do they have a stiffer sidewall than regular CTs? Does that affect the the contact patch when cornering? Has anyone tried both? |
Posts: 395 Moravia, IA | Nozzledog - 2011-04-10 11:25 AM
Yes, the sidewall is stiffer - its made to support the vehicle when there is no air in it. It doesnt affect the contact patch when cornering.
Never tried them on a bike....sorry, just passing along info from others.
The big reason I dont use on is because the sidewall is stiffer they can sometimes be more difficult to mount and you dont get the feedback from a low tire like you do with a regular tire. Id rather "feel" a tire getting a little low and get the problem corrected. |
Posts: 432 Gettysburg, 2008 Tour Premium | I have used the Ride-On-TPS for years in my bike tires. Even if it didn't seal punctures, and it does, the bike rides smoother with it in the tires. Less bounce or rebound over bumps.
Posts: 258 Akron, Ohio | Another Bridgestone 195/55/16 user here. I like the Darkside and doubt I will go back. The one thing that I will say is that air pressure SEEMS to make a big differance in the way the tire handles. I run 38psi in mine. To me this seems to be the sweet spot. At lower pressure the tire seemed too flat footed. At the higher pressure it handles more like the E3 did. So I would say that when you go Dark for the first time, take a guage and air pump with you and play with the pressure to get the feel you like. I started at 32psi and went up 2psi at a time till I hit 38. JMHO |
Posts: 388 Salisbury, NC | My first c/t was a Kumo run flat. The sidewall was stiffer, but bike rode good. Due to the higher weight of me and the amount of stuff I carry, I run 42 psi. I have a Michelin PRIMACY on now. The shoulders are rounded and ride great. Hope this helps. ET http://ImageEvent.com/etspastimes/rosiescartireinstalled http://photos.imageevent.com/etspastimes/rosiescartireinstalled/small/186.JPG
Edited by etspastimes 2011-04-12 7:38 PM
Posts: 101 Cold Lake Alberta Canada | It looks like there is a bunch of soild info here, I run the Potenza and love it.
Enjoy that trip, I have holiday envy in a big way! |
Posts: 432 Gettysburg, 2008 Tour Premium | Well my rear wheel is off and my Falken 195/55/16 is wait for a trip to the shop in the AM. A local repair shop is doing the work. They also did my fork fluid change. They mainly do metric. I chose the Falken because a GL1800 rider on their darkide forum said that tire handled very close to a M/C tire and he rides the NE PA roads. If anyone has ridden around the Delaware River you could understand the need for a responsive bike, lots of camber changes in the road and steep hills. Anyway that is why I went with the Falken. |
Posts: 395 Moravia, IA | wroman - 2011-04-24 6:31 PM
Ive heard good things about that tire as well.....let me know how you like it.
My Potenza has 30K miles on it......and its got half tread left......but I may change it out just to try something else. |
Central Wisconsin | wroman - 2011-04-24 6:31 PM Well my rear wheel is off and my Falken 195/55/16 is wait for a trip to the shop in the AM. A local repair shop is doing the work. They also did my fork fluid change. They mainly do metric. I chose the Falken because a GL1800 rider on their darkide forum said that tire handled very close to a M/C tire and he rides the NE PA roads. If anyone has ridden around the Delaware River you could understand the need for a responsive bike, lots of camber changes in the road and steep hills. Anyway that is why I went with the Falken.  Last year I installed the Falken Ziex ZE 512 195/50R/16 which has been a GREAT tire. I went with the 50 series account of the hitch doc. However I don't like the 3mph fast reading at 60mph. If anyone knows a way to adjust the speedo? Without changing to a 55 series, I'd be tickled pink.
Edited by Thomas 2011-04-24 9:31 PM
Posts: 395 Moravia, IA | Thomas - 2011-04-24 9:28 PM
Last year I installed the Falken Ziex ZE 512? 195/50R/16 which has been a GREAT tire. I went with the 50 series account of the hitch doc.However I don't like the 3mph fast reading at 60mph.? If anyone knows a way to adjust the speedo?? Without changing to a 55 series, I'd be tickled pink.>
No way to adjust that I know of.....I actually like the fast reading. I have a tendency to run a little fast anyways.....so this way I can run 65 to 68mph......and really not be speeding all that much. Mines more like 5mph off though.
Edited by aaronrkelly 2011-04-24 11:28 PM
Posts: 432 Gettysburg, 2008 Tour Premium | Well maybe Thomas can say how the Falken is wearing. I expect the potenza will beat the Falken from what was reported but a around half the price of an E3, so what. |
Posts: 1229 Rancho Cucamonga, CA | 180/60 = sidewall height of 106.55(4.195") or 24.39" dia - Stock Dunlop E3 (Dunlop spec for 16x5 rim)
195/55 = sidewall height of 107.25(4.224") or 24.448" dia
185/55 = sidewall height of 101.75(4.005") or 24.010" dia
195/50 = sidewall height of 97.50(3.838") or 23.676" dia
185/50 = sidewall height of 92.50(3.641") or 23.282" dia
205/50 = sidewall height of 102.50(4.035") or 24.070" dia
The smaller the diameter (off stock), the faster your speedometer will read.
A larger diameter tire will mean you are going faster than the speedo says.
With a smaller diameter tire, your odometer will rack up more miles than actual.
A larger diameter tire wil rack up miles slower.
Car tire measurements based on a 16x6" rim (actual diameter may be different)
Some of the 195 size tires darksiders are recommending are not recommended for 5" wide rims.
To keep a 50 sidewall, you would have to go up to 205 on the width. I don't know if that would work, even without the HitchDoc.
Edited by Nozzledog 2011-04-25 1:45 AM
Central Wisconsin | aaronrkelly - 2011-04-24 11:28 PM No way to adjust that I know of.....I actually like the fast reading. I have a tendency to run a little fast anyways.....so this way I can run 65 to 68mph......and really not be speeding all that much. Mines more like 5mph off though. Yeah...it does seem to provide a built in speed comfort zone. I'm just not happy racking up an extra 3 artificial miles for every 60.
Central Wisconsin | wroman - 2011-04-25 12:20 AM Well maybe Thomas can say how the Falken is wearing. I expect the potenza will beat the Falken from what was reported but a around half the price of an E3, so what. My Falken 512 195/50/16 as of today, has about 7000 miles. Measured the thread depth at 6/32" in center and 7/32" on the sides. Been running 38lbs of air, I think I'll drop down to 36lbs.
Edited by Thomas 2011-04-25 9:54 AM
Central Wisconsin | Nozzledog - 2011-04-25 1:24 AM 180/60 = sidewall height of 106.55(4.195" or 24.39" dia - Stock Dunlop E3 (Dunlop spec for 16x5 rim) I'm thinking of ordering this Dunlap SP Winter Sport 3D RunOnFlat http://gl1800riders.com/forums/showthread.php?t=262953 Dunlap website
Edited by Thomas 2011-04-25 10:48 AM
| I know that Dakota Digital makes a device to recalibrate your speed-o You could talk to them about adapting one to a victory |
Central Wisconsin | john frey - 2011-04-25 11:24 AM I know that Dakota Digital makes a device to recalibrate your speed-o You could talk to them about adapting one to a victory   Dakota Digital HealTech
Looks like one of these two could possibly work. Just don't want to put the money out for something that might work. I'll probably just buy the right size CT.
Posts: 1229 Rancho Cucamonga, CA | Thomas - 2011-04-25 8:46 AM
I was looking at the same tire, but I don't know if I want the 195/55 or the 175/60 (24.3" dia on 5" rim)
Would a narrower tire handle more like a MT? |
Central Wisconsin | I was looking at the same tire, but I don't know if I want the 195/55 or the 175/60 (24.3" dia on 5" rim) Would a narrower tire handle more like a MT? Don't know for a fact...you have about 5.7 inches of tread width on the 175/60/16. Compared to 6.5 - 6.8 inch tread width for the 195/55/16.
Posts: 1359 New Bohemia, Va | I'm curious as to how hot your tires are getting for those who run the darkside. There are other concerns in my mind, and maybe not a big deal, but the more I read about CT users the more I'm convince to stay with the rated stock tire for the bike.
Has anyone gotten down and checked the tempature on the CT after a good run?
Edited by Cap'n Nemo 2011-04-25 2:46 PM
Posts: 258 Akron, Ohio | I have felt the tire with my hand. It was warm to the touch. Felt about the same as the front.
Posts: 432 Gettysburg, 2008 Tour Premium | Jeff not trying to highjack your thread but the tire is on and just did 45-50 miles on various roads. At first I thought I had made a big mistake, did not like the handling at all. After riding this bike for a few years it just did not handle the same. Then I remembered to give the sidewalls a chance to brake in. Around 25 miles it did not feel as bad and I noticed it started to respond quicker to steering input. Ten miles later started to get a feel for it and better still. The real shocker is when I climbed up the mountain heading home I am thinking that I still do not like the feeling as much as a M/C tire. I glanced at the speedo and I was going faster than I usually do and it felt as if I was creeping along. So I did something a little out of character for me and I dropped a couple of gears and I came into the sharpest corner on the climb doing double the 25 posted and the bike never even gave an indication it was being pushed. After that I played with acceleration and under throttle the bike was very very stable. I cannot get over the feeling.
Edited by wroman 2011-04-25 5:46 PM
Posts: 23 Stony Mountain, MB Canada | I am almost at the end of the life of my stock tire, so now I am at cross roads as I have to put on a new rear tire before I leave on a fairly long trip at the end on May and don't know if I should put on a stock tire or go to the darkside.
So after reading all of the post on the Vision Riders site about the darkside, which is the best tire to go with?
Is it one of the following:
- Bridgestone Potenza G019 195/55-16.
- Dunlop SP Winter Sport (Run Flat) 175/60-16.
- General Altimax 195/55-16.
- Michelin Primacy 195/55-16.
Or is ther a different brand or type of tire that might work better than the ones listed above?
Has anyone had experience using more than one brand of darkside tire after they switched from the stock tire?
| I was wondering isn't the speed-o sensor in the motor and picks up a reading from a gears? I don't think the rear tire has any thing to do with the speed |
Central Wisconsin | john frey - 2011-05-03 6:03 PM I was wondering isn't the speed-o sensor in the motor and picks up a reading from a gears? I don't think the rear tire has any thing to do with the speed Can't say for a fact on how the Victory Vision speed sensor works. I can say that my bike odometer is on with my GPS odometer using a 175/60/16 rear CT . Before I was running a 195/50/16 CT and the bike odometer was clocking 2-3 extra miles for every 60 compared the GPS odometer.
Posts: 1229 Rancho Cucamonga, CA | Unless the speedometer is measuring the speed of the road going by, they all work the same. They are set to oem specs that state every revolution is with a 180/60-16 tire will move the bike 76.6 inches (24.4 x pi) forward. Where it measures the revolutions could be at the wheel or the transmission, doesn't matter. If you use a tire that is smaller by say 1/2 inches diameter, it travels 74.8 inches per revolution but the bike still thinks it is going 76.6 inches, so the bike is going slower than the speedometer reads, and not as far either.
Edited by Nozzledog 2011-05-04 1:15 AM
Posts: 825 , WI | etspastimes - 2011-04-12 7:34 PM My first c/t was a Kumo run flat. The sidewall was stiffer, but bike rode good. Due to the higher weight of me and the amount of stuff I carry, I run 42 psi. I have a Michelin PRIMACY on now. The shoulders are rounded and ride great. Hope this helps. ET http://ImageEvent.com/etspastimes/rosiescartireinstalled http://photos.imageevent.com/etspastimes/rosiescartireinstalled/small/186.JPG Any update on the Michelin Primacy? Are you using the Primacy Alpin? |
Posts: 262 Flowery Branch Ga | I recently went to ct on my 8 Ball. Freedom Powersports in Cummings mounted mine. Be prepared to wait. Dropped off the bike and tire on Sat. mod morning. It was ready mid day on Wed. Using the Potenza185-55-16. |
Posts: 142 elgin mn | Why wait rode my bike to my dealer unstrapped my Hankook Ventus V4 es 195/55/R16, hopped on a used Hammer, went to an apointment and 40 minutes later I was back paying $54 dollars to mount and install 3 oz of dyna beads. rode 150 miles and havent slowed down since. Install was done june 28 as of today have 5000 miles on tire,E3 would be 1/2 wore out!!!!! lovin the darkside |
Posts: 2118 Pitt Meadows, BC Canada | HaHaHaHa - you guys are a RIOT! Love reading this stuff ! Saves me all the trouble of thinking about MY problems. Keep it up !!!
Posts: 255 New Brunswick , Canada | Load Capacity: Bridgestone Potenza G019 195/55-16---------------> 1201 pounds
Dunlop SP Winter Sport (Run Flat) 175/60-16------> 1047 lbs
General Altimax 195/55-16--------------------------> 1201 lbs
Michelin Primacy 195/55-16-------------------------> 1201 lbs
Hankook Ventus V4 es 195/55/R16-----------------> 1201 lbs
The load capacity of the Dunlop is on the low side......riding two up is too much weight ! |
Posts: 1229 Rancho Cucamonga, CA | Lojak - 2011-09-08 8:31 PM
The load rating of the Dunlop E3 rear tire is 80 (992lbs) , so all those tires are rated better than OEM. |
| Go for the CT its a good ride and your speed-o doesn't change that much where you'll get a ticket. You can still scrap your floor boads and not even get over to the edge of the tire. If you look close you'll see I'm not close to the edge of the tire and I scrap as mush as I want.
 (IMG_0288.JPG)
Posts: 1229 Rancho Cucamonga, CA | Put the Dunlop Winter Sport on today. Took it to a local shop where I know the owner is a darksider too. 55 minutes later I'm on the road with a 175/60/16 CT and 2 oz. of Dynabeads under me. He had no issues mounting the tire to the Ness Rim, it seated with very little pressure. I was amazed considering all the war stories here. He said he filled it to 36psi but my TPMS says 38. To be honest, on the ride home, if I didn't know it was a car tire, I wouldn't have noticed a difference. The only thing I noticed was it felt a little out of balance. Do you think 2 oz of Dynabeads is enough for a CT? Didn't notice a thing on the freeway so it might have just been the truck worn street I was on. Or the thought of a CT under me was playing with my mind.
I like the look of it. It's kinda rounded and not real obvious that it is a CT.
I will get a better feel for it over the weekend.
Edited by Nozzledog 2011-09-17 3:04 AM
Central Wisconsin | Darrell, Good to hear the Dunlop Winter Sport mounted up nice. If the tire was out of balance I think it would have been shaking on the the freeway. I'm running 3 oz's of DynaBeads in mine. You probably know this already ... is the red dot on the tire next to the valve stem and all previous lead weights removed? Looking forward for your weekend review
Posts: 395 Moravia, IA | Nozzledog - 2011-09-17 3:00 AM
I bet it was the street. My Potenza really amplifies a "crappy" road....I run 3 or 4 oz of airsoft pellets in mine......Ive had the bike up to 118 and never a shake. |
Posts: 1229 Rancho Cucamonga, CA | Dots all line up. I had 1 oz. of weight on wheel before the install and it was taken off. I think it was just the road I was on and a need to feel something different riding on a CT. Today, most of my riding was around town and a little on the hwy. I couldn't feel any difference between the MT and CT. It even handled grooves in the road without a hitch.
I am planning a mountain ride across Angeles Crest Hwy. tomorrow and will be able to give a better evaluation then.
 (2011-09-17 16.50.07.jpg)
2011-09-17 16.50.07.jpg (45KB - 0 downloads)
Posts: 337 san antonio, tx | I miss that road! |
Central Wisconsin | Nozzledog - 2011-09-17 7:24 PM ... I am planning a mountain ride across Angeles Crest Hwy. tomorrow and will be able to give a better evaluation then.
Looks good! The 175mm width seems to really fit the bike well and the odometer should be dead on. Racking up more miles this week with my tire combination...Wisconsin - South Dakota/Wyoming - Wisconsin. Oh yeah!
Posts: 154 Cabot Arkansas | Nozzledog - 2011-04-25 1:24 AM
Ok I am running the bridgestone potenza 195/55 my speedometer shows 75 mph and my wifes Vision with the stock dunlop E3 also shows 75 mph,but my gps only shows 73 mph .I thought my larger diameter tire would show a Lower speed over the stock tire but it doesn't.We did 1800 miles last week and my odometer did show about 4 miles more than hers did.
Edited by Maverick 2011-09-18 8:17 AM
Posts: 1229 Rancho Cucamonga, CA | Calculations for a stock Dunlop E3 put it at a 24.503" diameter, slightly bigger than the 195/55-16 calculations (24.448" . This would make your speedometer read slightly higher than stock. The 24.39" diameter I quoted for the E3 was from the Dunlop spec sheet. The Pontenza spec sheet may also show that the tire is slightly smaller than the calculations would make it out to be. Bringing the sidewalls in to the 5" rim width may also reduce the tire diameter. |
Posts: 1229 Rancho Cucamonga, CA | Just did 75 miles of twisties across Angeles Crest Hwy today leaving a little floorboard metal as usual. Practically forgot I had a car tire on. The Dunlop has been superb!
On occasion, a low speeds on straight but uneven roads, I can feel the tire tilting to try and conform to the uneveness. I think this would even be more pronounced with a wider tire. A good analagy for any snowboarders out there, It's like going straight (flat) on a snowboard, you feel all the uneveness under you. When your on an edge, it goes away.
The plus is that it never falls into any cracks or ruts in the road, it spans right across them.
Edited by Nozzledog 2011-10-03 8:22 PM
