Fountain Inn, SC United States | For those that don't know, the Learn Lash Procedure is the order of adjustments/steps you run thru if your cruise control is acting erratic.
Based on his answer from another forum thread, here's what Kevinx shared:
1-Press & hold the resume & on/off buttons on the cruise control switch.
2-Turn the ignition switch on.
3-While holding both buttons, start the engine.
4- After the engine starts, watch the cruise indicator lamp on the indicator display until it goes out.
5-When the cruise control lamp goes out, release both buttons at the same time.
6-Press & hold the resume . the cruise indicator lamp should illuminate.
7-Listen for a brief increase in engine RPM(very slight RPM increase)as the cruise control module performs the procedure.
8- Release the resume button when the RPM drops down to idle speed & turn off engine.
The procedure is used when replacing the cruise control cable. The procedure takes any slack or free play out of the cruise cable where it connects to the throttle body.
