Posts: 394 Tucson, AZ | The heater on my seat will warm up then shut off until cold, then come back on again, then keeps the process all over again. I don't remember it doing this before. Is this normal? |
| Under normal conditions it should cycle on & off not stay on but I have never had mine cycle off to the point it was cold.My seat was replaced under warranty because it stopped working on the front side. |
| I aslo had my seat replaced under warranty due to the front position not working. It will shut of and turn back on by it self, but never to the point that it cools off. or completly yurns off. |
Posts: 732 Western WA | My seat was replaced under warranty as well for almost the same problem.
What year bike are you riding Gray Rider? |
Posts: 394 Tucson, AZ | She's a 08 Comfort Tour. Strange thing is last two times I had her out, the seat seemed to work fine. |
Posts: 732 Western WA | Well, you have the right year for the problem. Might be something very simple though. I know it sounds obvious, but have you pulled the seat and checked for a loose wire? |
Posts: 216 Danville, CA | I had my fuse blow on my 08 vision and my cruise stopped too.. Replace fuse and good to go.. check the fuse.. |
