CC Fairing on a CR
ricvic
Posted 2011-01-17 11:54 AM (#77444)
Subject: CC Fairing on a CR
Just curious..... will a Cross Country fairing fit directly on a Cross Roads (removing the CR windshield, turn signal light bar, headlight, and speedo, of course)??? Will the CR headlight fit the CC fairing?
Please don't ask why I am doing this....lol.
Victory XC
Posted 2011-01-17 1:21 PM (#77449 - in reply to #77444)
Subject: Re: CC Fairing on a CR
It will.
Bring your checkbook.
CrossRoads
Posted 2011-02-17 11:00 AM (#79584 - in reply to #77444)
Subject: RE: CC Fairing on a CR
Everything is possible if you have an unlimited budget.
Be aware that the handlebars are different (shorter) on the XR than on the XC, so you'll need to replace those as well.
Goatlocker95
Posted 2011-04-22 9:15 PM (#84614 - in reply to #77444)
Lexington Park MD
It would probably be alot easier (and cheaper) to use an after-market fairing. I haven't verified that it will fit but it does appear that a Wide Open fairing will fit. Under Model Compatibility it just states "Victory? Motorcycle: models require the factory windshield brackets."
http://www.wideopencustom.com/dotnetnuke/Fairings/tabid/60/Default....
randyyo
Posted 2011-04-22 11:39 PM (#84629 - in reply to #77444)
Leduc Alberta Canada
I would think it could be done but very expensive.
Bars are different, wiring harness would be different,headlight, signal lights
and list would go on and on.
Cheaper just to buy a Cross Country.
