Posts: 109 Sturbridge, Ma | Hi,
Has anyone installed this fuel controler on their bike? If so, any thoughts? Just curious if worth it on a stock bike.
Thanks!
http://www.magnumtuning.com/en/detail/evo-tech_motorcycle_fuel_cont... |
| I believe it is just an overpriced resister used to "trick" you ride. In other words, not a good AFR and possible long term damage. Plus a resister is like a quarter at radio shack. |
Posts: 258 Akron, Ohio | Don't waist your money. A buddy put one similar to this on his bike and it did nothing. |
| Like every one says do a power commander V or lloydz is the only good way to spend your money |
Posts: 109 Sturbridge, Ma | Thanks for all the feed back...But does Lloyds power commander ok on a stock vision.
Posts: 1632 Jasper, MO | Eric_MA - 2011-01-13 6:52 PM
Yes, and it allows you to retune for any performance enhancements you may do in the future, like intake, exhaust and cams. If you do anything to your Vision to let it breath better, you need the ability to add more fuel, which Lloydz VFCIII and the PCV both do.
Ronnie |
| What do you need it for on a stock bike? Trying for better gas mileage? Buy a Vespa.
Looking for performance spend the money and get all the goodies from Lloyd and do it right. |
Posts: 348 Sturbridge, Mass | Eric_MA - 2011-01-13 7:52 PM
Eric,
Give me a shout on fuelers and LLoydz stuff- I am having some owrk doen as well as working with a local dyno place that can work some magic.
Posts: 109 Sturbridge, Ma | Well I'm just checking on what I could add step by step.
I do S1L1 with K/N filter, but for me that stock? Just curious on adding some performance parts? |
Posts: 1484 LaPorte,Tx. | The intake plate is a low $, easy to install, hp boost for the Victory Vision with the S1-L1 set up. |
