Posts: 51 REXBURG IDAHO | HERE ARE THE PIC OF THE CATERPILLAR AIR LOUVERS THAT I INSTALLED TO GIVE MORE AIR FLOW TO THE MOTOR AND YOUR BUTT.
 (louver.jpg)
Posts: 177 NW Illinois | Not sure where your at so have to let us know when you test them in the heat
How was the install |
Posts: 1632 Jasper, MO | Looks good. Does much air come through them? Did you add any ducting to get more air?
Ronnie |
Posts: 51 REXBURG IDAHO | i rode with them on a warm day a did feel a lot of air coming through. drimel tool and made a tep plate before cutting. |
Posts: 51 REXBURG IDAHO | felt a big diff when i rode with them on a warm day no additional ducting and for 10.00 dollars a piece i think it will be a good fix for air flow. |
Posts: 51 REXBURG IDAHO | i am in cold idaho but we did have some warm days that after i installed the louvers i was able to feel a big diff of air flow. |
| I love simple solutions like this. Two things. When closed, how well to they stop air and water? How well do the stay closed, or did you have to make modifications to keep them closed at speed? |
| I wish you would tell us where you bought them.
Great idea I will think hard about doing mine.
Edited by john frey 2011-01-02 1:10 PM
Posts: 1229 Rancho Cucamonga, CA | Anyway to run the A/C to them?
Do they shift much? |
Posts: 111 Salina, KS | john frey - 2011-01-02 1:09 PM
I am sure any CAT dealer will be able to hook you up, as I believe he said they were for a CAT Haul Truck. |
Posts: 164 Quad Cities, IL | I am curious about this mod also. Do you have lower air-deflectors too...or was this an alternate to making that that investment. I have lower air deflectors which I think do a great job, but am curious about the added benefits of the louvers, if any. Appreciate you sharing this mod, I love the creativity of those on these forums!
Posts: 804 Perry Hall, MD | You might want to check out the following thread for some additional info on similar mod that SongFan installed. Others have also cut away part of the fairing to increase airflow, but of course there is no way to close that for cold or wet weather riding. It is amazing how many great ideas people on here will come up with.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2937&pos... |
Posts: 51 REXBURG IDAHO | any cat dealer should be able to get them or have them. they ar off a 785 c 150 ton haul truck i thought i had the part number just cant find right but i will get the number. |
Posts: 51 REXBURG IDAHO | i have no lower deflectors and yes it does shut off the air very well and for the rain i will have to let you know |
Posts: 51 REXBURG IDAHO | in idaho good ac right now no shifting with the two bolts on each louver |
Posts: 51 REXBURG IDAHO | PART NUMBER FOR CAT LOUVERS 8Y6388 |
