Oil Cooler Screen
Posted 2010-12-19 8:36 AM (#75817)
Subject: Oil Cooler Screen
After cleaning the bugs out of the oil cooler with compressed air and a toothbrush.
I decided to cut a ( 5" x 6 1/2" ) piece of galvanized hardware cloth for the oil cooler.
Attached the hardware cloth with some nylon lock ties.
You could use a different type screen, spray paint the screen black and/or use wire or thin hose clamps to attach.
Posted 2010-12-19 10:11 PM (#75860 - in reply to #75817)
Subject: Re: Oil Cooler Screen
Looks good.....Oh by the way if the Vision does not start reconnect the negative terminal. Just kidding. I am sure you disconnected it to make certain you did not get a short when installing the screen.
Keep up the good work!
Ride Safe
Posted 2010-12-20 9:06 PM (#75902 - in reply to #75860)
radioteacher - 2010-12-19 10:11 PM Looks good.....Oh by the way if the Vision does not start reconnect the negative terminal. Just kidding. I am sure you disconnected it to make certain you did not get a short when installing the screen. Keep up the good work! Ride Safe
Thanks...
I originally planned on cleaning the battery terminals since I had the front wheel off for a new tire.
Just couldn't stand the way the oil cooler looked so I cleaned it and protected it.
Oh...I decided to take off the factory negative cable and install a longer one. I routed the new negative cable through the hole to the left of the battery.
It really cleans up the cable/wire clutter and makes the black plastic wire/circuit breaker cover easier to install.
Edited by Thomas 2010-12-20 9:08 PM
