Garmin 755t GPS install
team5150
Posted 2010-12-12 6:34 PM (#75330)
Subject: Garmin 755t GPS install
Corona, CA
  I had this GPS on my wing and when I got my 08 Vision I decided to install it on it the same way. It's easy, convenient removable at stops and completely restorable to stock.
I have the 755t that has lifetime traffic updates. It is not waterproof but I don't ride in the rain much and even if I do it is pretty protected where it is and if it gets really bad - remove it or put a baggie over it.
The mounting I used is a plastic disc that had 3M tape om the back. I mounted it under the key and even without the GPS on it - it doesn't look out of place.
The suction cup mount just sticks on and is very stable and strong. I have gone thousands of miles with it and neer had an issue. If something did let go the power cord attached would hold on to it.
I took the 12v adapter off the end of the power cord and wired it into the plug for the powerlet in the left side compartment fished up to the left side and keep it between the fuel door and frame when not using it.
As you can see, you can take the unit off with out disconnecting anything. Put it in your pocket and you're off.
 It looks like it belongs there !
The screen on this model is very bright and I have never had a problem see or reading it in bright sunlight. It also has a SD card that you can load your tunes onto and listen to them through the pin jack in the right side pocket so it eliminates an iPod and gives you turn by turn and traffic info.
This is a shot with the brighness turned up.
Hope this helps someone looking to do an aftermarket GPS add on. It is a lot cheaper and you can update the unit as time goes on - one thing you really can't do with the factory units.
Posted 2010-12-12 10:16 PM (#75340 - in reply to #75330)
Subject: Re: Garmin 755t GPS install
Nice install! I do about the same thing with my Garmin.
Ride Safe
Posted 2010-12-12 10:26 PM (#75344 - in reply to #75330)
Duplicate post
Edited by radioteacher 2010-12-12 10:26 PM
Spaniard
Posted 2010-12-20 9:04 AM (#75870 - in reply to #75330)
Nashville
Well, I think is a great way to have GPS without spending the tremendous amount the dealer is asking. Personally, I think it is a rip off, but that is just my opinion.
After seeing your install, I am wondering two things:
a) Have you ever had a problem with the cup suction? I think it could be unsafe if the GPS were to come up loose while riding.
b) Has your GPS ever been affected by the vibration? I have the same GPS than you do (755T), and at the store, they said I need one for motorcycles due to the vibration a motorcycle produces. I am not sure if that is true or not....
Like you, I am not planning to ride on hard rain, and in the worse case scenario, I can buy a, somewhat, water resistant cover.
Also, since we have the same GPS, have you ever created a Course on your computer and then transfered to the GPS itself? If so, how do you do it? What programs do you use?
Thank you in advance
team5150
Posted 2010-12-20 3:47 PM (#75887 - in reply to #75330)
Subject: RE: Garmin 755t GPS install
Corona, CA
I have been running this GPS for about 2 years (5000+ miles) and I have never had any problem with it losing suction. If for some reason it did it has the power connector to hold it on until you can stop to fix it.
When you hard wire it - just cut the plug off and strip the ends. The ground is wound around the positive wire. The other big wire is the antenna for the traffic function.
Again, I have never had a problem with it and the vibration level on the Wing or Vision is not like a Harley so I don't think it is an issue. If it lasts 3-4 years I'm happy and feel like I got my moneys worth out of it. The 660's are $500-600 so you can go thru three or four 775T's for that price !
 At any rate it is MUCH better than being stuck with the factory one that can't be upgraded or replaced inexpensively.
I have created many "rides" for this unit. Last year we went to the Rocky Mountains with a bunch of Gold Wings and we downloaded GPS routes of a bunch of different rides like Pikes Peak, Rocky Mtn National Park, Independence Pass and they worked great ! You can also reverse the trip and follow it in the reverse direction if you want.
You can set up your route in Streets & Trips 2010 or MapSource (Garmin's product). Mapsource is a little more difficult to use. S&T is much easier and is easy to download to your unit via the USB cable.
Just set your route using the trip planner and then use the "download .GPX file" to your hard drive so you can save your trips or hit the "send to device" button and it will send it directly to the connected device.
Spaniard
Posted 2010-12-21 6:01 PM (#75938 - in reply to #75330)
Nashville
Thank you so much for the help. I can?t wait to get her ready this winter, and with no hesitation, this datailed info will help me tremendouly. I never thought that GPS on a bike could so behelpful until now. There are so many back roads that need to be explored. A GPS will make exploring a lot easier. Hopefully, I will have the same rate of success than you had with yours.
Once again, thank you a bunch and happy riding.
