Posts: 109 Sturbridge, Ma |
Hi,
I'm the process of taking my center console apart to get painted, i unplugged the plugs from below. Didn't realize there was 3 plugs on the heated grip switch. Blue, white and cooper like. Now I don't know what order now they go....Can someone help? Thanks!!!
Is this the order?
Low=Blue
Middle=White
High=Cooper like  |
Posts: 1484 LaPorte,Tx. | For the 08 Vision, the service manual says the wire colors are as follows:
Front - BN
Center - BU/PK
Rear - BU
Don't know what year you bike is, but I would say your probably right on the order you believe. The BN is probably your Copper color and the BU is the rear wire, so the white is left for the center. Good luck. |
Posts: 109 Sturbridge, Ma | thanks! This site Rocks!!! You are right!! Its that my plug is white, but the BU/PK.
thanks for the quick response!!!  |
Posts: 367 Cottage Grove, Mn | I learned a long time ago that a digital camera can be your best friend when it comes to such things. |
Posts: 1359 New Bohemia, Va | Wires are a lot of fun if you don't mark them when you remove them. On things like the heated grip switch, as long as you have the white plug in the middle, the worse that can happen is the switch works backwards. I like Blackjack's idea since most phones have camera's and I have mine close at hand most of the time. This is really a great site! |
Posts: 109 Sturbridge, Ma | I agree...but theres isn't much room to take a picture with anything below the console. Working on my winter projects are fun! Lol |
