Posts: 3204 Memphis | Just posted this in the Tech Reference section. Should be a great help all the way around. http://vision-riders.com/bb/forums/thread-view.asp?tid=7538&posts=1 |
| Great photos. I did read if you pull the air filter it gives you more room.
You should post this under the tech section so it doesn't go away.
Good Job.
PS always replace both bulbs ask the auto parts guy for his best ones.
Edited by john frey 2010-11-24 12:23 PM
Posts: 3204 Memphis | Thanks John. I just updated the link and tweaked it a little. It is posted in the Vision Tech Reference section which does not allow replies so if anyone has corrections or additional tips, let me know here and I'll update the Tech thread. |
Posts: 179 CARTAGENA Spain | Songfa hols in the picture you posted I see that the completion of the bulbs is not the same as I have, my bike is a victory vision 2008 and the bulbs are carrying a H-11, I guess you have another model bulbs or I have bought are not worth my bike, I have not dismantled the lighthouse to check because I see a lot of work to be worth then not. I can confirm that the H-11 are correct
Posts: 8144 New Bohemia, VA | if they still have the assembly out, I would have like to see the HID boot off. I thought regular bulbs were held in by the screw too until I took apart. It appeared some one did not pay attention at the factory and missaligned the wire and the screw was holding down, preventing it from hinging. It works fine now.
So my next question is, if it does require a screwdriver, how do you replace the HID without removing the entire assembly? |
Posts: 3204 Memphis | Adolfoch - I just replaced the original headlight bulbs on my '08 Vision (47,000 miles) and they are H4's. I've never heard of H11's in a Vision. Is yours European? What is the non-HID driving light bulb if you don't have HID in there? VaRyder - I'll try to get back over there next week and get a pic of the HID bulb in the housing. That was a warranty headlight assy that was being returned to Polaris (cracks across the top of the clear headlight lens, very obvious) so it might not be there when I go back. |
Posts: 3006 San Antonio, TX | Nice write up!!! I am still on my original bulbs....I am sure that one will fail soon.
Thanks! |
Posts: 935 Rockford, IL | I have pictures of the back of the HID in my gallery. |
Posts: 3204 Memphis | Link to the Lotzafun HID photo: http://www.vision-riders.com/bb/photos/show-album.asp?albumid=269&photoid=2788 The two phillips head screws hold that gold strap on that holds the HID bulb in. |
Posts: 1484 LaPorte,Tx. | Tom, thanks for the photos and the write up. Now I think I might be able to do it is the darn things burn out. Also, your dealer is just the greatest. Next time I'm in Memphis I'll have to stop by and buy something!  |
Posts: 8144 New Bohemia, VA | Thanks SF for pointing out LZF photo gallery. It's like discovering that bad thing about your wife that you never knew before because your still reeling from the honeymoon. Man, if my HID ever blows I'll have a true out of body experience trying to replace without pulling the housing. You know they did give you an angled screwdriver in the kit, you reckon that is what this is for?
Edited by varyder 2010-11-24 5:56 PM
Posts: 3204 Memphis | I put the Lotzafun link to the HID pic in the Tech write-up. You could get it (the HID) out but lining everything up and not dropping one of those little phillips head screws down the black hole on the reinstall would be impossible. I begged my dealer for the HID bulb in that housing but it has to go back as a set. |
| adolfoch - 2010-11-24 10:11 AM
According to the owners manual h-4 is the correct headlight bulb. |
Posts: 179 CARTAGENA Spain | Buy them on e-bay, thinking they were such as indicated, Kingpin 2008 Victory Vision Hammer H11 Headlight Bulbs
I had an error and will now have to purchase the H-4 and thanks for the clarification
Posts: 599 New Mexico | Well, at 41k on my 2009 I just noticed one of my bulbs is out. Not sure how I will get my hand(s) in there to replace, but sure appreciate all the info.
Thanks guys.
Edited by Boots 2012-12-29 3:34 PM
Posts: 741 Central New York | Great pictures, great job! I still am a believer in taking out the assembly to change the bulbs. Even if you can work your hands around enough to change the bulbs without removing the assembly, there is no way to insure the boot is in place properly.
Again, thanks for the great pics. |
Posts: 599 New Mexico | Stopped by dealership and asked how much to replace bulbs - $30!! Dropping off on Monday, a happy boy...
