Struggling with VFC III Install
ByteN2it
Posted 2010-11-20 11:42 AM (#73934)
Subject: Struggling with VFC III Install
I read everything available about this install and began yesterday afternoon after receiving my VFC in the mail. Using long hook nosed pliers and a long screw driver I popped off the front injector connection no problem first try-the rear one is still attached after several attempts and the red retainer top popped off on my last try-I can see the release lever pushing in as I gently wiggle/lift the connector but can't seem to get it to release, and now the whole assembly seems kind of loose. Decided to back up and return to square one-that front O2 connection was a bitch to get snapped back together. Bike seems to be running fine but I know that rear injector connector's a bit beat up and now I'm just regrouping and contemplating how to get where I want to be. Any help would be greatly appreciated. Thanks, Brian
2009VVTP
wroman
Posted 2010-11-20 7:30 PM (#73955 - in reply to #73934)
Subject: Re: Struggling with VFC III Install
Gettysburg, 2008 Tour Premium
Moral support is all I have to offer. Not the easiest thing Iv'e done. I spent some time just working the connectors on and off using the VFC connectors to practice. I used WD40 to make the going easier. The thing you have to realize is that it does not take much effort.
ByteN2it
Posted 2010-11-21 9:40 AM (#73974 - in reply to #73934)
I appreciate the support-I was just taking a deep breath and thinking out loud, I'll give it a squirt of WD prior to my next attempt. Perhaps a ride in the cool mountain air will clear my head and I'll give it another go in the near future. Thanks, Brian
yoyo
Posted 2010-11-21 9:53 AM (#73975 - in reply to #73934)
ESCALON CA.
i used one hand( middle finger mainly) from each side
nohawg
Posted 2010-11-21 10:27 AM (#73977 - in reply to #73934)
Fargo, ND
I did too along with some colorful metaphors. Then I proceeded to remove the clips from the injectors.
 It honestly took me almost 2 hours total to get those little bastards unclipped and clipped back on. Definitely the hardest part of the install.
Edited by nohawg 2010-11-21 10:29 AM
tonyj
Posted 2010-11-21 8:26 PM (#74013 - in reply to #73934)
Salina, KS
The front O2 sensor connection is easier to access by removing the plastic shield at the front of the engine. You can also go to your local NAPA & get 2 each, male/female GM Weatherpack connectors & 4 seals to plug onto the disconnected ends of the O2 sensors & harness so corrosion won't get in them should you ever remove your VFC3.
