Posts: 258 Akron, Ohio | I know the 08 manual says to use 92 octane fuel. When on the trip last year we could not always get it and I had to use 89 and even some 87. The thing that I found from this is that my bike runs better on the 89 octane then the 92 or 93. My milage is better and the idel is smoother. I actually gain about 4 miles per gallon using the 89. We ran through some low 90* days and I never had an octane knock. My bike does have the L1S1 that was done before I bought it. Just curious as to what others are running. If yours is not listed, please add it. |
Posts: 849 , FL United States | I use 89 mid-grade in Florida and Georgia. When I get much above sea level or out West, I use 92 or 93. My Vis just runs better that way. |
Posts: 444 Bay of Gigs, WA | I heard that if you use middle grade the thing pops less. I tried it and it seems to work for me, without knocking. Don't know if I should change my brand of oil or not for doing that... |
Posts: 258 Akron, Ohio | I will agree about the popping. Seems worse with the higher grade fuel. |
| Try to use 93 as much as I can, epecially if it is hot and riding two-up. Mine rattles really bad under hard acceleration on 91. |
Posts: 446 East TN | Whatever the highest octane I can find...either 91 or 93 is best I can do here in East TN |
Posts: 3773 Pittsburgh, PA | My manual in my 08 says 90 octane. I use anything about 90. A few times I used 89 with no problems |
Posts: 74 Lehigh Valley, Pa | Normally I run mid grade with no issues. During the winter I will drop to regular with no issues, If I run regular during the warmer months It will ping. |
Posts: 204 West Knoxville TN | Mostly hi grade |
| My Vision has never popped. I have run regular in her because that was the only grade the station had on a trip. That tank seemed to burn through quick. When in the Black Hills I get about 2 MPG better than home. Difference I see is 3,000+ feet there and 50+ feet at home. More oxygen less mileage? O.o |
Posts: 494 Akron Ohio area | At sea level, you will need a higher octane level when compared to being in the high desert or mountain states.
You will see available octane levels in the 85 range at higher altitudes.
The 2011 Vision calls for 91 octane.
I will run 91 or greater during the break-in period. |
Posts: 8144 New Bohemia, VA | i tried the lower octane in mine here in Va and it sounded like it was coming apart it pinged so bad. I tried it several times, from low to mid and I had no choice but to go back to 92/93 Octane. |
Posts: 258 Akron, Ohio | Arkainzeye - 2010-10-21 9:02 AM
The shop manual says 92 octane for an 08. Weird that they are different.
GENERAL SPECIFICATIONS
Victory Vision? Street / Victory Vision? Tour Specifications
All specifications are for standard Victory Vision? (Street or Tour) models. Specifications may change with the addition of custom order options and
/ or accessories.
2008 Victory Vision? Street / Victory Vision? Tour
Oil Capacity 5.0 Qt (4.75 ltr) (Approximately 4.65 qts.or 4.25 ltr at oil & filter change)
Fuel Capacity 6.0 US Gal (22.7 ltr) (1.0 U.S. gal / 3.8 ltr reserve)
Fuel Type / Octane Minimum Premium Unleaded / 92 Octane
Dry Weight Street: 804 lbs (365 kg) / Tour: 849 lbs (385 kg)
Wet Weight Street: 844 lbs (383 kg) / Tour: 889 lbs (403 kg)
Gross Vehicle Weight Rating 1414 lbs. (641 kg)
Gross Axle Weight Rating* Front: 513 lbs (233 kg) / Rear: 901 lbs (409 kg)
Overall Length Street: 103.5 in (262.9 cm) / Tour: 104.9 in (266.5 cm)
Overall Width 45.2 in (114.7 cm)
Overall Height 58.5 (148.5 cm)
Seat Height 26.5 in (67.3 cm)
Ground Clearance 5.8 in (14.8 cm)
Passenger Capacity 1
Wheelbase 65.7 in (166.9 cm)
Rake / Trail 29 Degrees / 5.4 in. (13.7 cm)
Edited by handyhiker 2010-10-21 5:09 PM
Posts: 21 London, KY | I have used Regular in my '08 since I bought it with approximately 1000 miles on it. I did have a mild ping when cold a few months ago...had the dealer check the software and it has been fine since. I have found that Premium in this and my other bikes over the years seems to make them run hotter in temp. I have a Volvo XC90 with the 2.5 Turbo and I have used Regular in that since I bought it used. I did pull the plugs on the VV last week at 10K miles and they were surprisingly clean...light brown with just a little carbon on the front one. New plugs did make a difference...definetly noticed it when in 6th gear and lowish RPM. I also believe that the lower priced gas stations have fresher gas...so I use Speedawy, Pilot and the like....never had a problem. Did the Dragon last week and the VV ran like a top on rails...hate it when my bike is so much better than I am! Ride Safe |
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | I use regular 87. I pull a trailer with a motocross bike on it. The total weight including me, passenger, trailer, dirtbike, dog, gear, etc. is over 750 lbs. The motor has detonated only once when I was 2 gears too high exiting a turn on an uphill.
The motor is completely stock including the pipes. I only use Shell or BP. The elevation here is 700ft. 87 octane seems to work fine in my particular case. Motor mods, elevation change, quality of fuel, etc will problably yield different results. |
Posts: 1117 Northeast Ohio | I run premium (93) because Lloyd told me to.  |
Posts: 3006 San Antonio, TX | I run premium 93. My wife read the sticker that said to run higher octane fuel on the Vision and then TOLD me to always run Premium!
Thanks Victory. |
Posts: 619 Southeast Iowa | 91-93 octane from Shell or BP when possible, others work but anything below 90 likes to ping under load or hard acceleration. Not sure why some say higher octane does funny things like run hotter, pop, and so on. I'm far from an expert but too much octane should not cause any of those things. My guess is the brand of gas that they use has more to do with it than anything. |
Posts: 394 Tucson, AZ | I run 91 octane because it's the highest I can find in these parts. Generally I buy from Valero. I like to run some Chevron threw the ole gal once in a while for a treat. I also use some Sea Foam a couple of times a year as well. |
