Battery voltage drop vision
adolfoch
Posted 2010-10-12 5:17 AM (#71487)
Subject: Battery voltage drop vision
CARTAGENA Spain
Hi all, I've noticed that when he stepped on the brakes from the battery indicator drops below 14. Does anyone know if this is normal, this happens or someone else has my bike is a 2008 victory vision of a greeting
Posted 2010-10-12 5:24 AM (#71488 - in reply to #71487)
Subject: Re: Battery voltage drop vision
Not while underway, that is not normal. Maybe while sitting that is normal.
adolfoch
Posted 2010-10-12 5:30 AM (#71489 - in reply to #71487)
Subject: RE: Battery voltage drop vision
CARTAGENA Spain
then I'll have to take it to the shop the problem is that is 300 km
Posted 2010-10-12 5:42 AM (#71490 - in reply to #71487)
so are you saying there is a voltage drop while you are riding the bike and touch the brakes?
adolfoch
Posted 2010-10-12 6:15 AM (#71491 - in reply to #71487)
CARTAGENA Spain
Yes, but not I have to do
Posted 2010-10-12 6:20 AM (#71492 - in reply to #71487)
hopefully others will respond. If your bike starts okay, that is the biggest burden, your battery and charging is okay. My first guess is that maybe you have a short in your brake light circuit.
If your bike does not start well, or if your headlight is dim then it maybe a battery or charging problem. I hope I'm helping you.
adolfoch
Posted 2010-10-12 6:27 AM (#71493 - in reply to #71487)
CARTAGENA Spain
Not if the regulator will issue just because the battery fully charged and now has no such voltage drop when he stepped on the brake, or perhaps is that the battery is in the past, you who believe varyder
adolfoch
Posted 2010-10-12 6:27 AM (#71494 - in reply to #71487)
CARTAGENA Spain
Posted 2010-10-12 6:54 AM (#71496 - in reply to #71487)
sounds like your issue is gone if I'm reading right, translation is a little tough. So if it was just a short lived problem that is now gone, it may have just been a weak battery. Always keep your battery fully charged, some use a battery tender that will trickle charge when you are not riding. This keeps the battery up all the time so you'll be ready to start. A weak or bad battery can cause other problems in your bike that may need to be fixed if you keep it too long.
buzz64077
Posted 2010-10-12 8:52 AM (#71507 - in reply to #71496)
orrick, mo
I've had the voltage move around on my bike but it has always been that a battery cable has worked loose. I try to remember to check them every couple of weeks now.
handyhiker
Posted 2010-10-12 2:38 PM (#71531 - in reply to #71487)
Akron, Ohio
My 08 voltage will drop at a stop with the brakes on. It normaly runs just over 14 volts on the guage, sitting with the brakes on it drops below 14. Can't remember exactly how far, but it drops. As soon as I hit the throttle, back up to just over 14.
adolfoch
Posted 2010-10-14 1:16 PM (#71632 - in reply to #71487)
CARTAGENA Spain
Yes, that's what I get and see what happens handyhiker same, from what I understand is normal. Greetings to all from Spain
adolfoch
Posted 2010-10-14 1:19 PM (#71633 - in reply to #71487)
CARTAGENA Spain
Another question you know where there is a post that indicates how to disassemble the back to change the light bulbs
