Clutch Assist
Uncle
Posted 2010-10-10 12:32 PM (#71355)
Subject: Clutch Assist
Newburgh,IN
Hey Gang:
Has anyone had a Clutch Assit Mechanism or an EZ Clutch installed on their Vision.
Thanks
Dave
Tarpits99
Posted 2010-10-10 2:29 PM (#71360 - in reply to #71355)
Subject: Re: Clutch Assist
North Orange County CA
The Vision has a hydraulic mechanism so the ez-clutch type products are not an appropriate fix to reduce lever pull.
Some guys with carpal tunnel or arthritis have switched the Vision components out with those from the XC or the Vision 8 Ball which I understand use a cable actuated clutch.
Im sure somebody on the board can tell you how to do it and what parts you need.
Posted 2010-10-10 3:04 PM (#71363 - in reply to #71355)
yes, i'm waiting to hear more on this subject. I may to go this route, especially in the cold where functionality of my left hand drops dramatically and I refuse to stop riding because of it.
lennyb
Posted 2010-10-10 5:10 PM (#71369 - in reply to #71363)
Perry Hall, MD
Chris,
If you can hook up with Teach I believe that he did the conversion - not sure if he posted anything here that would explain it.
Tarpits99
Posted 2010-10-10 5:46 PM (#71371 - in reply to #71355)
Had to put on my thinking cap, after a little searching I found these links for you.
http://forums.thevmc.com/bb/forums/thread-view.asp?tid=90421&posts=...
http://forums.thevmc.com/bb/forums/thread-view.asp?tid=90486&posts=...
Good luck
baadawg
Posted 2010-10-10 7:08 PM (#71378 - in reply to #71355)
Chattanooga, TN
Uncle Dave,
I changed out the clutch fluid a few weeks back. The clutch had gotten hard to pull and didn't fully engage when released. It has gotten 100% better since the change, like new once again. It was a pain in the arse to bleed when I accidentally ran the clutch reservoir dry, but worth it. Now, you've been warned!!
Posted 2010-10-11 6:27 AM (#71391 - in reply to #71355)
Thanks TP99, I'm doing my homework on this but I don't see anywhere what the devise looks like, the E-Z clutch, or how it is installed or what the cost is, I'm still looing though, and thinking. Things are kinda tight at the moment and I don't want to be screwing around with the bike and not be able to ride at all. While looking for E-Z clutch information I came across other clutch helpers adding to my confusion. Fortunately I believe I survive another winter as I got it figured out how to disengage my clutch when I lose my overall grip in the cold.
glighto11
Posted 2010-10-11 7:50 AM (#71398 - in reply to #71355)
Subject: RE: Clutch Assist
Central New York
varyder - If I were in your situation I would look at a different direction.
I would look for a used master cylinder from a "parts out" Vision wreck.
I would then examine if and how the piston cylinder could be bored out and by how much.
A "friend" in a machine could spin you a new piston if needed. Or maybe just some oversize rubbers.
I would think a few thousandths increase would make a huge leverage difference.
XRsteve
Posted 2010-10-11 8:40 AM (#71399 - in reply to #71355)
Georgia, west of Atlanta
This could be important for all of us as we stretch out our riding careers.................
Tarpits99
Posted 2010-10-11 9:29 AM (#71401 - in reply to #71355)
"Give me a place to stand and a lever long enough and I will move the world" Archimedes, 220 BC
From what can tell its just a longer ,fancier lever to replace the stock clutch actuating lever. Gotta love "modern" technological advances.
http://www.victoryonly.com/ACCESSORIES/easy_clutch.htm
Edited by Tarpits99 2010-10-11 9:30 AM
yoyo
Posted 2010-10-11 10:02 AM (#71403 - in reply to #71355)
ESCALON CA.
had to make my own for wifes 2010 vegas , she loves it.
cw1115
Posted 2010-10-11 4:34 PM (#71448 - in reply to #71355)
Ruskin, Fl
I have no problem with the pull on mine as of now. Id get that just cause it looks good!
Uncle
Posted 2010-10-12 9:04 AM (#71509 - in reply to #71355)
Newburgh,IN
Guys:
Thanks for the suggestions. I will have to dig a little harder. My 08 isn't super hard to pull or anything, but I'm not 20 yrs old anymore either. Might check into replacing the fluid.
Thanks
Dave
Uncle
Posted 2010-10-12 9:07 AM (#71510 - in reply to #71355)
Newburgh,IN
Tarpits:
It says it will not work on my 2008 Vision. Too bad for me.
Dave
Uncle
Posted 2010-10-12 9:09 AM (#71511 - in reply to #71355)
Newburgh,IN
Thanks Baadawg!!
sgiacci
Posted 2010-10-12 11:11 AM (#71521 - in reply to #71355)
There is a small company in CA that made a billet slave cylinder conversion for my Spyder, and it works great.
Maybe if enough of us ping on him, he might think it is a worth while venture to make one for the Vision.
Thier web site is:
http://evoluzione.net/evo-cycle-can-am.htm
I have already pinged him.
