Darkside question....but its about the FRONT tire.
aaronrkelly
Posted 2010-10-05 2:58 AM (#71011)
Subject: Darkside question....but its about the FRONT tire.
Moravia, IA
Im already running the car tire on the rear, love it.
Ive read a few people will run a rear MC tire on the front for extended mileage.
Are any of you doing it and if so what tire are you using and how do you like it?
etspastimes
Posted 2010-10-05 7:14 PM (#71086 - in reply to #71011)
Subject: Re: Darkside question....but its about the FRONT tire.
Salisbury, NC
The only ct I have seen on the front of a bike are bobbers. ET
aaronrkelly
Posted 2010-10-05 10:38 PM (#71109 - in reply to #71086)
Moravia, IA
etspastimes - 2010-10-05 7:14 PM
Ehh, I was asking about running a rear MC tire on the front....thought maybe someone had some recommendations.
Im thinking of trying a Avon Venom rear on the front.
etspastimes
Posted 2010-10-06 6:53 AM (#71116 - in reply to #71011)
Salisbury, NC
My bad, I had a couple of toddies before I got on the puter. Bobbers are the only bikes I have seen with a ct or rear tire on front. ET
bigfoot
Posted 2010-10-07 10:55 AM (#71181 - in reply to #71011)
Akron Ohio area
Why?
donetracey
Posted 2010-10-07 11:59 AM (#71183 - in reply to #71011)
Pitt Meadows, BC Canada
You gonna change the design of the forks and the braking system, as well as finding a rim wide enough to handle a rear tire. And finding a 21" ??? rear tire narrow enough to fit on the stock rim? Or ???
WHY !
donetracey
Posted 2010-10-07 12:08 PM (#71184 - in reply to #71011)
Stock Vision wheel sizes: Front - 3.00 X 18 (not my guess of 21), Rear - 8.5 X 18
glighto11
Posted 2010-10-07 1:01 PM (#71185 - in reply to #71011)
Central New York
I am just trying to understand why motorcycle and tire manufacturers spend hundreds of thousands of dollars each year on designers and engineers when all we need is a frame with something round and and black at each end.
cw1115
Posted 2010-10-07 1:49 PM (#71186 - in reply to #71011)
Ruskin, Fl
The rear is a 16" and way too wide to fit on the front anyway.
aaronrkelly
Posted 2010-10-07 5:51 PM (#71210 - in reply to #71181)
Moravia, IA
bigfoot - 2010-10-07 10:55 AM
Why?
better mileage
cw1115 - 2010-10-07 1:49 PM
I dont mean the rear Vision tire....I mean a rear tire in general.
donetracey
Posted 2010-10-07 6:56 PM (#71212 - in reply to #71186)
cw1115 - 2010-10-07 11:49 AM The rear is a 16" and way too wide to fit on the front anyway.
I guess I'll have to check my back tire - the Vision manual says it's 18" front AND rear on page 3 of chapter 14 as follows:
Front Wheel
Front Wheel Size 3.00 x 18
Rear Wheel
Rear Wheel Size 8.50 x 18
Finding an 18" REAR tire to fit on a skinny rim - hmmmm - not sure how that would give better mileage - if you could find one .....
etspastimes
Posted 2010-10-07 7:43 PM (#71222 - in reply to #71011)
Salisbury, NC
I guess the rear tire I just installed (195/55/16) should have been a little bigger to get it on the wheel. Huh. I do know they make a 18" rear tire. Just not on the Vision that I have. As far as putting a rear tire on front, I'm good with how it is now. And good luck finding a rear tire small enough to fit. ET
aaronrkelly
Posted 2010-10-08 6:24 PM (#71304 - in reply to #71222)
Moravia, IA
etspastimes - 2010-10-07 7:43 PM
Its a common enough size I can find them everywhere.....open your mind a bit.
Avon Roadrunner is what Im thinking of using.
etspastimes
Posted 2010-10-08 7:17 PM (#71306 - in reply to #71304)
Salisbury, NC
The first part of my statement was to DoneTracey about an 18" rear. I know they make them also, but my wallet says no way for my Vision. As far as you wanting to put a rear tire on the front of your bike, go for it. To each his own, if I could help, I'd be there with a tire spoon in each hand. Let us know how it feels. It should change the feel a little. ET
Edited by etspastimes 2010-10-08 7:18 PM
Posted 2010-10-08 7:39 PM (#71307 - in reply to #71011)
http://www.bikebandit.com/rear-sport-touring-130-70-18-street-motor...
...here's the bike bandit's listing for the rear tires that fit the front of the Vision...however, they all seem to be bias...
Edited by varyder 2010-10-08 7:50 PM
