Posts: 576 , IA | What is the size socket I need to buy to remove spark plugs will b using smaller size ratchet 3/8" |
Posts: 8144 New Bohemia, VA | 5/8 |
Posts: 404 San Antonio, TX United States | best served with the proper plug socket and a 3 inch extension. I happen to prefer the 5/8 universal joint plug socket since i change plugs in all the victory bikes and some that people put there own custom parts on. So i can always get in with that set up. A nice set of long handled curved needle nose pliers is good for gripping the plug wire and levering against the cylinder head to pull them off cleanly with out pulling the wire out of the crimp. Of course put a rag or something soft between the needle nose pliers and the cylinder head. |
Posts: 3773 Pittsburgh, PA | 5/8 i use the little extention its only a few inches long. |
Posts: 8144 New Bohemia, VA | I keep a 1/3 cut of a hose to put on the cylinder head fin to protect when using the needle nose to pull the wire. |
