| I know this has likley been discussed before...but... the Victory dealer says to use only the Victory motor oil. They say other synthetics such as Amsoil or Mobile 1 will result with poor clutch action.
I've been around bikes alot of years and seems if the oil is designed to work with a wet clutch it should work with the Victory...
I'd like to use a full synthetic Moblie 1/Amsoil/Royal purple...
Anyone out there using somthing different than Victory oil in their Vision??
thanks |
Posts: 8 Prescott, AZ | I use AMSOIL 10W-40 Synthetic Motorcycle Oil (MCF). It's 100% synthetic and API SL/CF. One of the biggest advantages of AMSOIL synthetic motorcycle oil is the wide temperature range. The pour point is -51°F and the flash point is +453°F. That's a 504°F temperature range! No matter how cold or hot it is outside, the oil in my Victory Vision is not a concern.
AMSOIL motorcycle oil also provides excellent wet clutch performance. "AMSOIL MCF contains no friction modifiers and promotes smooth shifting and positive clutch engagement. AMSOIL MCF controls heat and prevents slippage and glazing, helping improve clutch life. AMSOIL Synthetic 10W-40 Motorcycle Oil meets the wet clutch frictional requirements of MA/MA2 as outlined in JASO Standard T903: 2006."
I also use the AMSOIL EaO13 oil filter on my Victory Vision. It is a perfect match for the Polaris #2540086 oil filter that came on the motorcycle. In fact, it is apparent that both oil filters are made by the same manufacturer!
Don't forget to buy a supply of "Oil Drain Washers" for the oil drain plug from your Victory dealer. The Victory part number is 5812232 and the washers cost 75 cents apiece. You should use a new washer every time you reinstall the drain plug.
| wow!
thanks, I sort of figured the dealer was giving me a marketing pitch... |
| thanks!
I sort of figured I was getting the Victory marketing pitcth. |
Posts: 2027 Brighton, TN | I've been using MOBIL 1 synthetic since the first 500 mile oil change. Put in the mobil 1 oil filter and I call it good. My dealer also was trying to get me to use the Victory Blend. But knowing that they don't produce the oil, they buy it from somebody and put their label on it, is no different than most brands. I'm sure the Dealer has a larger profit margin on the Victory brand. If I did, I would probably try to get you to use it. However, if I really wanted to get you to buy it I would make it comparable in price to what is on the market. I can buy the full synthetic Mobil 1 for around 8 bucks a quart. The Victory Blend is 8 or 9 and it is semi-synthetic. If I am going the synthetic route might as well go all the way.
Edited by pollolittle 2008-03-17 8:36 AM
| "If I am going the synthetic route might as well go all the way."
Thanks for the chuckle. You do know that Mobil 1 comes from dino oil base? Thank a federal judge for that.
Amsoil and only 2 others are true synthetics. It would be nice to cut back on foreign oil dependency too. At least the semi-synthetic admits to not being true synthetic. |
Posts: 2027 Brighton, TN | Alright, since I obviously don't have a clue. Please provide what data you have to support your claim. I am the first to want to learn more. I saw the statement between Mobil 1 and Castrol how they redefined synthetic and the cost associated with it. So, if all I am doing is wee weeing money away. Then I might as well go back to just straight motor oil. I have a car that has over 200,000 miles on it and it is still happy, never used synthetic in it all. Let me know be glad to hear. |
Posts: 223 Valdosta, GA | Yeah, an oil thread!!!!
I am currenlty using Amsoil. I've used other oils in Vic engines (Mobil1, Rotella, Vic, etc) and have found Amsoil seems to work best FOR ME. Over the years, others have claimed to have had issues with using Amsoil in thier Vics, primarily with clutch slippage. I have no reason to doubt their claims, but can only attest to what I have experienced.
With other oils, I could tell when the oil had outlived it's usefulness. It was generally around 2,500 miles I would begin to notice shifting issues, excessive noise, and difficulty getting to neutral. It was more prevalant with conventional oils than with semi- or "full" synthetics, but by 3,000 miles all other oils I tried were READY to be changed.
I still change my oil roughly every 3,000 miles even with the Amsoil. It's just an old habit that's tough to break. But if I happen to be on a trip and realize I've surpassed the 3,000 mile mark, I don't worry about it. And it's more apt to happen like that now, as I'm not seeing the issues I previously had letting me know I need to change the oil soon. Luckily, the Vision has a second trip meter to keep track on my oil mileage...
Posts: 49 west bend, wi | BlueOx USA - 2008-03-17 1:14 PM
".... You do know that Mobil 1 comes from dino oil base?..."
I read this a while back as well but just went looking to find the proof.... I can't find anything that states that Mobil 1 is anything but full synthetic. In fact it says 'full synthetic' all over the Mobil website, documentation and the PI specs. Does anyone know the truth? |
Posts: 2027 Brighton, TN | Ahh the truth, leave it to PR and marketing to bury it. This must be the part where resistance is futile and I give up and just use what I want. There no issues. Just change it occassionally and ride the rest of the time. YAHOOO! |
Posts: 1484 LaPorte,Tx. | If you read this, http://www.sportrider.com/tech/146_0308_oil/index.html and part 2 of this article you will gain a lot of knowledge on the age old issue of "What Kind of OIL", or not. If you gleen these articles you will figure out Mobil 1 base stock. Hope this helps. |
| Haven't checked it out yet but might be a good source of info.......
http://themotoroilsite.com/forums/
I also have a copy of the "Motor Oil Bible" which has a lot of information on oil, it can be had for free from the site linked above. |
Posts: 82 Northwest of you | I am pleased to see that "Oil" threads are so well received on this site. On other sites, there is often a moan when someone asks about oil and you will hear the famous "here we go again" cry. I, on the other hand, happen to love them and so here is my "take" on it. First off, if you want the best technical answer I have seen, read Mark Lawrence' article All about oil. Then get some Shell Rotela T synthetic at wal-mart and while you are there pick up their oil filter (made by the same company and to the spcs of Mobil 1, ST7317, I think). You will save yourself a bunch of money and I think you'll be better off. |
| great discussion...I guess my question at this time is has anyone actually experienced first hand or have first hand knowledge of clutch problems the Vic dealer warns about when using full synthetic oil? I usually view dealer warnings such as this rather lightly, but I do not want to assume...
I know Amsoil is supposed to be recommended for the Victory... and the only experience I have to go on is that I used Mobile 1 10W40 motorcycle oil in the primary on my Electra Glide (I traded for the Vision) with no clutch problems...in fact there was an improvement...
Don't want to beat this horse too much longer, just trying to do good research
thanks
Former Harley Rider
08 Victory Vision - Black
Northern Alabama |
Posts: 732 Western WA | nowor2l8 - 2008-03-25 1:16 PM
I have used the Rotela syn from WalMart in two bikes and never had a problem.
I put 18,000 on an 06 Suzuki C50T with a K&N oil filter and the thing purrs like a kitten and the clutch is as good as the day I picked it up. I still changed the oil at 3000 (because I'm paranoid), but I have known folks that went longer between changes and have suffered no ill effects.
But oil is like food - everyone has their favorite.  |
Posts: 72 Eyota, MN | I used Amsoil 20w-50 in my Kingpin from 5000 miles to 33,500 miles, all year round, and it ran flawlessly. I plan on switching my Vision at 5000 miles also. I like to let the engine breakin good with the Victory oil first then switch it. |
Posts: 293 Arkansas | I'm pretty sure that Mobil1 is a PolyAlphaOlefin. Amsoil was the first of this type
and is full synthetic, non dino base stock. I' used it(M1) in my HD's and my GL1800 and in
two previous Victory's; never a problem and I know where all these bikes are now(except for
the vegas) and they are still problem free!
Just had to put in my 2 cents!
Edited by jama 2008-03-26 2:09 AM
| I use AMSOIL also and my dealer said it was fine. |
Posts: 47 Adamsville, Tn | Do you know the part numbers for the Rotella oil and filter? |
Fountain Inn, SC United States | Lloyd Greer uses Amsoil in his bikes, including his race bike. |
Posts: 2027 Brighton, TN | Breaker or nowor218, I have never seen a Rotella Synthetic for Bikes or their filter at Walmart. I see their Shell Rotella for Diesel Trucks which I use. So, got a number on either like stretch was asking.
Edited by pollolittle 2008-04-02 11:19 AM
Posts: 732 Western WA | Might be the part of the county you live in pollolittle whether WalMart stocks the oil or not.
I'll go see if I have a bottle in the garage and get the numbers for you. |
Posts: 82 Northwest of you | The filter is with the other "bike" filters and it's number is ST7317. The oil is the one you are refering to, Shell Rotella T (in the blue jug) synthetic 5w-40. |
Posts: 732 Western WA | nowor2l8 - 2008-04-02 4:37 PM
The filter is with the other "bike" filters and it's number is ST7317. The oil is the one you are refering to, Shell Rotella T (in the blue jug) synthetic 5w-40. i
Yep, 'blue jug' Shell Rotella T.
I see that K&N isn't currently making a filter specifically for the Vision yet. I have liked the K&N.
Once again, I don't have the bike yet, so are any of the other Vic (K&N) filters interchangeable? |
Posts: 47 Adamsville, Tn | don't want to hijack a thread but , Hey pollo I was at frs a few weeks ago and asked if they had to do any work on a vision yet. They said nothing mechanical but they had to do some body work on one. Was that yours? |
Posts: 2027 Brighton, TN | yep |
Posts: 1117 Northeast Ohio | You can also get the Shell Rotella T (blue jug) at AutoZone.
I used this in my Kingpin with no clutch problems, but I do feel it shifted too smooth. I also had a harder time finding neutral with it. The bike ran a lot quieter with less scissor sound.
John |
Posts: 3773 Pittsburgh, PA | BlueOx USA - 2008-03-17 2:14 PM
The federal ruling your talking about is not that mobil1 is made from dino oil. its that GroupIII base stock can now be classified as Synth. Thats all the ruling means. And not All mobil1 oils use groupIII base stock. Amsoil does use the higher base stock oil. But in most tests the mobil1 with the lesser basestock But high additive package comes in 2nd place everytime. I have heard more than a few people say that when they used mobil1 and amsoil motorcycle oil, that the amsoil mc oil gave them smoother shifting |
Posts: 619 Southeast Iowa | I'm currently using Amsoil in my Kingpin and it works great. The Vision will get it when I dump the oil in another 1000 miles. Some have been using 20-50 but Amsoil reccomends 10-40 for Victory. Both will probably work fine but I'm following what Amsoil says is the best match. Filters come from Parts America (Puralator) and are about $6. Total cost of an oil chage is about the same as Victory but I run the bikes to 3500 instead of 2500 miles which saves $ overall. |
Posts: 235 Evergreen, CO | If you are going to use synthetic oil and extend your change intervals, do yourself a favor and spend a couple of extra $$$ for a high quality oil filter. K&N, Mobil1, Amsoil all make a filter to fit the Vision. Some of their lookup tables do not specifically include the Vision, but it is my understanding that the Vision uses the same oil filter as all other 2008 Victory motorcycles. There are many posts on this forum about oil filters, numbers, preferences, etc. My contribution will be that I use the Amsoil EaO13 oil filter, which you must either order directly from Amsoil, or through an Amsoil dealer. K&N and Mobil1 oil filters are easier to find at Wally World, parts places, etc. |
