New Vision owner-BLACK oil
renorider
Posted 2010-07-04 11:35 PM (#63794)
Subject: New Vision owner-BLACK oil
Reno, NV
Loving my '10 Vision 8 Ball. Few disappointments. Have 2467 miles on it and completed the 2500 mile oil change last night. The oil that drained out was the blackest oil I have ever drained from a motorcycle. I filled with the Victory semi-synth 20W-40 (pretty clean yellow). Had the dealer do the 500 mile service + exhaust/air filter right at 500 miles and I assumed they used the same oil. I always change my oil on schedule and have never seen oil that black with under 2000 miles. Is this typical?
jama
Posted 2010-07-04 11:55 PM (#63795 - in reply to #63794)
Subject: Re: New Vision owner-BLACK oil
Arkansas
Yep, pretty much. Nature of the beast. No harm; just costs a little more than some to comply with the recommended interval. Some use different oils and extend their intervals a bit. I'm not weighing in on the "which oil" part, just so ya know. :-)
Flatsix
Posted 2010-07-05 7:30 AM (#63809 - in reply to #63794)
Subject: RE: New Vision owner-BLACK oil
Fargo, ND
I'm thinking the 'black oil' is a V-Twin thing.  The Harleys I have owned previously did the same thing.  The Gold Wings don't seem to get nearly as black.  Go Figure!
Edited by Flatsix 2010-07-05 7:31 AM
Posted 2010-07-05 9:12 AM (#63815 - in reply to #63794)
it's an 8-Ball... everything is black...
Posted 2010-07-05 10:26 AM (#63827 - in reply to #63794)
the blackness of the oil is due t blow by gas and it cleaning. you might say well what is there to clean if the bike is new.. if everything isnt seated well yet from break in, it is more than likely blow by gases that the oil has picked up. over time and milage this wont be as black. but also it depends on the oil you use and if you idle alot. right on im using mobil1 oil and i have close to 2k miles on it and when i wipe the dipstick its still pretty darn clean. but the color of the oil doesnt mean anything is wrong..
VaParadox
Posted 2010-07-05 10:51 AM (#63832 - in reply to #63794)
Richmond, Virginia
aree with all above, color isnt a concern, sediment particles etc etc yes. I noticed that my bike oil when i changed it first time from dealer oil was as black as my bike. Changed my oil to Amsoil and its not as black with these oil changes. Not sure why there is a difference
and doesnt hold a lot of value to me, but it was just something I noticed. My bike runs with no hiccups, pings, backfires, misfires, pops, farts,
belches, or leaks, so im a happy man. Welcome to the group, but I wouldnt sweat it bud. !
exharleyrider
Posted 2010-07-05 7:38 PM (#63857 - in reply to #63794)
On the harley black oil was usually due to running the engine cloe to overheating on a hot day.
rebel715
Posted 2010-07-08 11:39 AM (#64049 - in reply to #63794)
Winchester, Virginia
Also keep in mind that these bikes have 'wet' clutches, so our oil is also doing double duty with the clutch plates too.
nailer
Posted 2010-07-08 11:50 AM (#64051 - in reply to #64049)
Albuquerque, NM
Anyone have a magnetic drain plug. Just curious if any metal particles were found on a subsequent oil change. I bought one and put it aside for my next oil change. My wife put it away somewhere and I'm still trying to find it...ARGHHH!
paulhu
Posted 2010-07-08 12:19 PM (#64054 - in reply to #63827)
Durango, Colorado
Arkainzeye - 2010-07-05 9:26 AM the blackness of the oil is due t blow by gas and it cleaning. you might say well what is there to clean if the bike is new.. if everything isnt seated well yet from break in, it is more than likely blow by gases that the oil has picked up. over time and milage this wont be as black. but also it depends on the oil you use and if you idle alot. right on im using mobil1 oil and i have close to 2k miles on it and when i wipe the dipstick its still pretty darn clean. but the color of the oil doesnt mean anything is wrong..
     +1 I have noticed that as the motor has continued to break in my oil gets less dark with every change. The ring seating process seems to be progressively sealing the combustion gasses more effectively as the miles rack up. 8000mi. on now.
      Also agree with the "Big Twin" and "Wet Clutch" statements above regarding oil condition at change time. The oil change interval suggested by Victory is based on these and other conditions particular to this motor.
Posted 2010-08-10 6:54 PM (#66840 - in reply to #63794)
Say why not send your oil out and get it annualized and them you will know whats what.
I know victory doesn't like you to use amsoil cause amsoil has additives that keep the oil brown.
hoosiervic
Posted 2010-08-10 7:23 PM (#66842 - in reply to #63794)
Indianapolis, IN
I agree with all that's stated above. I will add that the blackness is mostly caused by carbon, dirt and probably the wet clutch. If you aren't using oil, meaning not having to add between oil changes, you have nothing to worry about.
Vic's have been around for over 11 years and their track record is just getting stronger.
Ride often and have a ball.
iluvink
Posted 2010-08-10 9:20 PM (#66859 - in reply to #64051)
Dallas, Texas
nailer - 2010-07-08 11:50 AM
I"ll let you know on my next oil change.
Posted 2010-08-10 9:32 PM (#66861 - in reply to #66859)
iluvink - 2010-08-10 10:20 PM
...did his wife give you the plug???
donetracey
Posted 2010-08-10 11:12 PM (#66871 - in reply to #63794)
Pitt Meadows, BC Canada
For GOSH sakes - get your dealer to change your oil. CRIPES. How MANY times do I got to tell y'all !!!!
That way you don't:
1. SEE THE COLOR
2. WORRY ABOUT HOW MUCH TO PUT IN
3. SYNTH or NOT
4. MANUFACTURER OF OIL
5. WHERE TO BUY THE CRAP
and so on, and so on. Spend the time you save making love to your precious other. Or polishing, or LEARNING something, or ANYTHING ELSE!!!!
LIFE IS TOO SHORT TO SPEND IT WORRYING ABOUT ....... o i l
CRIPES.....
hoosiervic
Posted 2010-08-11 6:07 AM (#66876 - in reply to #66871)
Indianapolis, IN
donetracey - 2010-08-11 12:12 AM For GOSH sakes - get your dealer to change your oil. CRIPES. How MANY times do I got to tell y'all !!!! That way you don't: 1. SEE THE COLOR 2. WORRY ABOUT HOW MUCH TO PUT IN 3. SYNTH or NOT 4. MANUFACTURER OF OIL 5. WHERE TO BUY THE CRAP and so on, and so on. Spend the time you save making love to your precious other. Or polishing, or LEARNING something, or ANYTHING ELSE!!!! LIFE IS TOO SHORT TO SPEND IT WORRYING ABOUT ....... o i l CRIPES.....
 Easy Don, I can see the veins in your forehead bulging out through the computer screen. ;-)
I agree, often we get caught up in the really little things in life when we could be out enjoying the ride with our best friend.
 Ride much and ride safe!
Posted 2010-08-11 8:50 AM (#66888 - in reply to #63794)
donetracey,
I think it is time to switch to decaffeinated coffee and tea. On second thought, you might want to take the wife to Empress Hotel in Victoria, BC for afternoon tea. Yes, that would be a very fine ride.
Ride safe to your happy place.
