| I purchased the power commander 5 knowing that Lloydz cams and intake are only a couple $$$ away in the coming months for my vision. I currently have the sl1 with the k & N air filter with Victory's map update (of which sucks).
I had my local dealer Mennetos in Clifton Park NY due the commander install (I have no time right now and that is why the dealer install). Mennetos did a nice job on the install (3 hrs charged to me) along with correcting my belt alignment (I noticed too much belt dust underneath) on the vision. They told me I was the 1st Vision in the area with the commander 5 install that they knew of.
I just got back from a 90 mile ride and the power commander 5 is a night and day difference to the Vision. This sucks real bad for a person who pays 21k + for a bike on the assumption that the bike should run real purdy on a dealer map.....wrong!
The power commander is very noticeable from the previous Victory (updated,,,cough BS -cough - BS) map.
The power commander was definitly worth the price and now I can only hope that my money tree grows quicker so I can get the "AutoTune, intake, cam and carriers"
That is my story and I am sticking to it  |
Posts: 3773 Pittsburgh, PA | i agree with you .. i installed my PC5 this past march or april and i noticed right off the bat a better cold start.. No surging until it warms up. I have a 2008 vision with the S1L1 setup WITH the sucky victory fuel map. i was shocked how much better the bike runs in all gears.. And all i did was just add a fuel controller to my setup. i even used the pc5 to help me tune my device from lloyds to help with popping. i plugged my laptop into the pc5 and got a REAL tach reading. i noticed the analog tach on the bike and the digital tach arent on the same page. the digtal tach (by using the PC software) was a little lower. |
Posts: 323 Troy, NY | I saw your post LEDS and went straight to Mennetoes. Ihad to get service so I'm having themm install the PC V with auto tune. I didn't think a dealer would install the PCs. I let everyone know how the PC with Autotune turns out.
Posts: 2300 Georgia, west of Atlanta | This is getting good, more info from all over the country................ |
Posts: 669 Peachtree City, GA | Check out all of the other threads on the PCV... |
| Hopefully, they will charge u less since mine was their 1st vision  |
Posts: 323 Troy, NY | How much did they charge you? I'll let you know. I'm probably the 1st they put the auto tune on....so I won't get a bargain-lol. |
Posts: 323 Troy, NY | Well after a month after the first PC V and Autotune installation - it's working. The dealer initially installed the wrong Autotune model. The catalog they ordered the part from only had the "universal" Autotune. For the Vision the Autotune module is the same as the Harley. AT100 is the correct model. When they first installed the whole setup with the wrong Autotune every seamed fine. This is because the Autotune just started doing it's work on one cyclinder. I took a trip on the Mohawk Trail and my gas mpg went to 30mpg. I knew something was wrong. Ooops I forgot to mention the dealer didn't give me the PC V plug. So I couldn't hook the bike up to by laptop yet. Low and behold, I figured out they installed the wrong Autotune. The dealer fixed it for free. I had to pay the difference of the Autotune cost which was fine. So I thought everything would be fine. Nope! The autotune was setup with the Engine Temp selected at 160 degrees. No problem except the PC wasn't configured to read the tempature. So, the Autotune wasn't doing anything. I unselected the Temp setup on the Autotune configuration and now I have Autotune tables to trim. Finally!!
I do have a question out of this. Using the PC V does anyone have the Temp configured? There is two options: Analog and Harley ECM. I tried the Analog but didn't give any values after I ran the bike. I think there is another wire to be installed to get the analog reading. I didn't try the "Harley ECM" option to see if that registers. Anybody have any other suggestions on the PC V software setup for the Vision. I'm at the playing stage now that I know everything is working. |
Posts: 669 Peachtree City, GA | I don't use the temp setting - just use the time delay to start adjusting... Works great!
