Fountain Inn, SC United States | http://www.mcnews.com/mcn/usedbike/2010MarUsedBks.pdf
Released for spring 2010, this is a guide to prices for all makes & models.
Remember this is a GUIDE, your bike may differ based on condition, mileage, features, and current geographical market conditions.
Posts: 447 Northeastern Penna. | As always, this is a guide, but may not be inline with some other publications. |
Posts: 935 Rockford, IL | The BEST way to properly value any vehicle, motorcycle, boat or similar is to get a value from at LEAST three or more different sources and then add these values up and divide the sum by however many sources were used. This helps to level out the roller coaster of high and low values. I can't tell you how many hundreds of times thru the years I've seen values differ by several thousand dollars using one source and another source, such as kbb.com and nada.com
Oh yea...Jeff...thanks for the link !!
Posts: 1484 LaPorte,Tx. | The best value on a motorcycle is the amount of smiles it adds to your life. You only have one life, but you can have several motorcyles. The Vision adds more to my life than I could have imagined before buying it. Ride on fellow Vision - Riders...especially VAryder out there somewhere. If you don't like the Vision...and you have one, hey, here is what you'll get. See ya. |
Posts: 1290 Ruskin, Fl | huh, Vision isn't listed with the other Victory models. |
