| when pushing in the truck release button,,, the trunk opens but the button stays in... have to pull it out with my fingers or use the key to gently pull it back out.. feels like the spring inside the lock might have broken.. got it scheduled to be looked at, but has anyone else had this issue....? |
Posts: 1484 LaPorte,Tx. | Very well could be the spring or what ever pushes it back out, you may want to try a silicone spray lub around the button. Could be alittle dry. |
| I lubed her up like a ********... no luck with it ... But thanks for replying  |
Posts: 8144 New Bohemia, VA | take the trunk off and get the passenger back rest and luggage rack, see problem solved. That'll be 5 cents please! |
Posts: 192 Republic of Tejas | Have a luggage rack mounted on it? |
| OldGringo - 2010-06-23 7:55 PM
Nope |
| Took it to the dealer... Dealer said a spring in the rear trunk lock broke... not a serviceable item... they have to replace the whole trunk lock asembly, and side bag locks and ignition switch at the same time to all be on the same key.. Sounds like overkill for what is probably a .50 cent spring... but hey,,, its under warranty Parts are on order, they said at least a week or two. So I keep riding till it comes in,,,, no worries here. I'll update when they get er finished.. |
