Posts: 9 , FL | Anyone know of any major engine issues, Like a rod knocking. 2010 vision
Thanks
Posts: 26 North East Oregon | Only issues I have heard of involves the valve lifters. never heard of any rod problems. |
Posts: 492 Indianapolis, IN | bwhittaker - 2010-06-20 8:07 AM
Thanks
6250 smiles after 11 weeks of ownership and I haven't even found a loose screw yet!!!  |
Posts: 8144 New Bohemia, VA | bwhittaker - 2010-06-20 9:07 AM
Thanks
70,700 - no problems - 2,600 mile trip to the desert starting the end of the week... (5,200+ round trip) |
Posts: 340 Regina Saskatchewan Canada | I don't think the Vision has push rods, does it? Self adjusting chain driven overhead cam with hydraulic lifters. |
Posts: 156 dinwiddie, va | he didn't mean push rod. he meant the connecting rods. From the piston to crank? |
Posts: 255 New Brunswick , Canada | 2010 Vision...1500 miles...ticking at start up for a minute then stop....don't like it..oil level ok..hhhmmm!!! |
Posts: 523 seattle, wa | This might sound crazy but.. when ya first start the Vision ya gotta make sure it's standing upright, not laying over on its sidestand, it seems to get oil into the pump lil bit quicker? If my bike sits for any length of time it takes a few seconds for the oil to get up to the heads, but it seems to get there faster if I stand it up before I start it. |
Thanks
bwhit - are you having a concern already? or is this just a general question? |
Posts: 3773 Pittsburgh, PA | When I used victory oil my cold/dry starts were noisy. Almost as if the oil took a tad bit longer to get up top? |
Fountain Inn, SC United States | rwilly is right. FastFred on this forum had this issue. The kickstand was actually defective and tilted the bike a little too much and the pump couldn't scavenge enough oil. Replaced the kickstand and the knock went away. |
Posts: 1484 LaPorte,Tx. | A person who knows the 106 Freedom motor inside and out told me the oil pump - side stand lean angle issue was casued by the reduction in the 106 oil capacity vs. the older Freedom motors that had an extra quart of oil in the oil pan. So if you have a defective side stand or start the bike on the down hill slope...you may experience valve lifter clatter. So if that happens, I think you will notice it goes away when starting the bike in a more up right position. |
Posts: 284 mansfield, MA United States | Jedi Jeff - 2010-06-21 7:07 AM
Jedi is right. I had the same problem and they changed my kickstand. I thought they were nut?s!!!!! but it worked. I now only start the bike upright.
Edited by Fastfred 2010-06-21 10:48 AM
Posts: 3006 San Antonio, TX | Fast Fred,
What year is your Vision and if you know, when was it manufactured? |
Posts: 9 , FL | 2010. I bought it last Dec 09 in St Pete fl. Only 12k miles. use 20-50 AMS only.
I noticed sometime it ticked louder if started while on kickstand. Dealer/Victory seem to think it cam belt tensioners.
Thanks |
Posts: 3773 Pittsburgh, PA | when i picked up my new speedo yesterday there was a 09 vision at this dealer where it has been to 2 other dealers with NO luck in fixing the engine noise. the dealer i was at believe the other 2 never really looked into fixing it and just blew the customer off. they removed the engine and found the rear cylinder has a broken PIN up but where the cam is... so they put it back in and still have a noise. they believe now it might be (because) of the pin the self adjusting lasher might be bad.. they think it was never getting oil properly in the first place.. i feel bad for the poor guy. his bike has been down and out for months. not because of this dealer but because of the other two that wasted his time..... |
| you wear a speedo????????? Not onthe vision i hope. |
Posts: 2300 Georgia, west of Atlanta | Anything can go wrong, but I'd be surprised at a bad connecting rod. The side by side rods, one piece crank and plain big end bearing almost make this a bullet proof bottom end. Having said that all engines need the proper amount of oil flow under pressure to live.............. |
| Before we would dismantle a engine. Check the 4012101 Sensor, Throttle Position In the earlier bike a defected one will make a bike sound like a rod coming out of the block. |
Posts: 8144 New Bohemia, VA | 73,000 miles...tick, tick, tick gets louder toward the end of the oil life and it is time for a change. Minz has always had some sort of tick, tick, tick, but with no problems... |
Posts: 2118 Pitt Meadows, BC Canada | Funny... my heart does that too
Guess it helps not idling myself on my side(stand)... |
