Posts: 348 Sturbridge, Mass | Hi,
I have the 2720 unit that needs to have the screen repaired. Since it is an OEM model, Garmin wants $170 to fix (versus $99 for non OEM) .
I can get the Zumo 660 for $540 (after rebate).
Should I fix the 2720 or go for it ?
I know I will need a new mount for the Vision, but assume the wiring harness will be the same.
Thanks
Jeff |
Posts: 68 LONDONDERRY NH | I bought a refurb with warranty 2720 for $149 on fleabay |
Posts: 1117 Northeast Ohio | I would personally go for the Zumo. I have the 2820 (2720 with Bluetooth) that I got for $300 last year new. The screen is small and can be tough entering an address on the fly. A real PITA if you know what I mean. I would also recommend the lifetime map updates for $100. With all the construction happening, it is nice to know that you can update for the life of the unit. |
