Posts: 172 Prescott, Az | I'm in mid Ohio on my way back to Arizona and my tranmitter on my CB quit working. I can recieve only. The cables/ground are all tight. I sprayed electronic lube into the switches. Nada. Anyone have any ideas???? Radioteacher? |
Posts: 3006 San Antonio, TX | Necktie,
I wont be much help here my CB has never worked to my satisfaction. I keep forgetting to take in my headset gear to the shop so they can test it.
I was thinking of buying a cheap CB transmitter so I can have someone talk to the radio for a receiver test. My only test set that makes AM signals to test the receiver is a Koren War era vacuum tube signal generator. It is 60 years old but it works great.
If you have a watt meter you can see if it is transmitting.
Sorry I cannot be of more help.
Ride Safe! |
Posts: 172 Prescott, Az | Thanks RT
I guess all I can do is get it home and let the dealer have at it. If it means buying a new CB then it will stay this way. |
