Posts: 576 , IA | what type of grease do u coat your trailer hitch ball with thanks |
Posts: 75 McHenry, IL | I don't use any grease. I coated my hitch ball with some dry film graphite (Super Slip). Comes in a spray can and dries in 2 minutes.
http://www.acrolube.com/ |
Posts: 412 Fargo, ND | I carry a small amount of vaseline with me. |
Posts: 160 Lennox, SD | When I was towing I used to use a piece of waxed paper, does the job without the mess |
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | I have never lubed the ball. Is there a need to lube it? |
Posts: 367 Cottage Grove, Mn | Aluminum Foil |
Posts: 162 Extreme Southern, AZ United States | Piece of waxed paper. |
