cb antenna
Posted 2010-05-18 6:13 PM (#60115)
Subject: cb antenna
my cb antenna just fell off at the base. I can screw out the base and replace it. I've done no checking yet and wonder if anyone has just replaced the antenna with other than the original. What did you get?
rlreed
Posted 2010-05-18 6:15 PM (#60116 - in reply to #60115)
Subject: RE: cb antenna
Tavares, Fl
I've broken two of them, have to go to Siera Electronics to pick up my third. It just unscrews. Sierra electronics is a good place to find them...
Gandalf
Posted 2010-05-18 6:37 PM (#60117 - in reply to #60115)
NW Jersey
The J&M antenna. Part #VAS-100. It's 12" but works very well. Only $18 from Overby's http://www.twowheelsound.com/antenna?b=1
Travelin Man
Posted 2010-05-18 7:52 PM (#60125 - in reply to #60115)
Subject: Re: cb antenna
The factory accessory CB antenna is made by Firestick for Victory, just google Firestick and you will get to their website where you can purchase any of their antenna that will work with the base that is mounted on the Vision's trunk (They also supply the mount to Victory). One of the items they carry is a CB and FM signal combiner, basically it allows the FM receiver and CB to share the same antenna and this works quite well from what I have read. One note though, it works when using a CB antenna for the FM receive, but you can't use a FM antenna to receive and transmit the CB signals.
Posted 2010-05-18 8:22 PM (#60128 - in reply to #60115)
Thanks folks. I'll check all the information out.
