Posts: 395 Moravia, IA | As the posts says. Im looking to add an accessory that needs ON/OFF switch.....figured someone had a part number or line on the right switch to snap in the empty spot on the dash panel.
Thanks a bunch. |
Posts: 249 Montreal, QC Canada | 4011317 is the part #. You can find all parts at this site
http://parts.polarisind.com/Browse/Browse.asp |
| Be prepared. I checked and either of the switches were almost $30 each. I just picked up a rocker switch at an electronics supply for about $2, It snapped right in. It's not water prrof, but in less you submerse it, it will never be a problem.
Edited by rikrok 2010-04-28 6:14 AM
Posts: 70 Central Victoria, Australia | illuminated switches would be nice, to confirm they are on!!
if you find a supplier, i think there would be a few takers,
victory should put them on our wish list for model upgrades, the rest of the dash is so well lit, its seems an oversignt
Posts: 64 St. Louis, MO United States | I took one of my switches to an Autozone and found one that matched nearly perfect. Not water proof but it fits perfectly in the last available slot on the dash. Used mine for LED lighting. |
Posts: 301 Buffalo Grove,Ill | I was thinking the same thing but bringing the forward seat heater switch to the dash. (screw the passenger) LOL |
Posts: 62 ESCALON CA. | I AM ALSO LOOKING FOR A MOMENTARY SWITCH TO USE WITH MY FLASH TO PASS GARAGE DOOR OPENER. |
| yoyo - 2010-04-28 8:12 AM
Escalon??? You guys have garages in Escalon lol (Manteca here)
I was thinking about a rocker for the flash to pass also. How do you like that flash to pass? |
Posts: 366 Albuquerque, NM | If anyone has the dimensions of the dash slot for the switch handy, I can look for an equivalent switch at Newark, Digikey, Mouser, or MCM. Will look for momentary function, lighted, and maybe weather resistant properties. I source electronic parts like this at work all the time.
Edited by nailer 2010-04-28 10:45 AM
Posts: 104 Plainfield Illinois | Cherry makes all kinds of rocker switches. Illuminated or not, also momentary if you want that.
http://www.cherrycorp.com/english/switches/rockers/index.htm
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | I'm going to use an accessory switch to power the lighted Victory badges on the sides of the bike. (Currently, they only come on when the key is on.) Then I can sit at the streetside eatery and watch the badges catch the attention of passersby.
Edited by victoryvisiontour 2010-04-28 11:00 AM
Posts: 446 East TN | Rakk17 - 2010-04-28 11:38 AM yoyo - 2010-04-28 8:12 AM I AM ALSO LOOKING FOR A MOMENTARY SWITCH TO USE WITH MY FLASH TO PASS GARAGE DOOR OPENER. Escalon??? You guys have garages in Escalon lol (Manteca here) I was thinking about a rocker for the flash to pass also. How do you like that flash to pass? WHY??? Just tie the flash to pass in on your high beams and it works...I've had mine for 9 months now and LOVE IT...Just hit the high beams twice and doen..>Garage opens and all is good...
Posts: 446 East TN | Ploz58 - 2010-04-28 7:54 AM illuminated switches would be nice, to confirm they are on!! if you find a supplier, i think there would be a few takers, victory should put them on our wish list for model upgrades, the rest of the dash is so well lit, its seems an oversignt Yep I would replace all of mine if there were exact replacement for the stock one!! |
Posts: 935 Rockford, IL | The solution is contained somewhere in this multi-page thread.... http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2120&sta... |
