| I just bought a 2008 vision....used ...as is...
Got it home and noticed the clock flashing, 12:00 (flash flash )
Then noticed I could not hold the mode button down, to access anything in the LCD display where the temp is, I can not get it to listen to me. I tryed turning the radio on and holding the mode down and the radio off and holding the mode button down, no effect on LCD display at all.
Any ideas?
(first post for help btw)
Edited by roadgrit 2010-03-28 11:00 AM
Posts: 3773 Pittsburgh, PA | maybe disco the battery for a few minutes and reconnect and try from there. only takes a few mins to try that one.. |
Posts: 3006 San Antonio, TX | To set the clock:
Toggle the trigger switch on the left handle bar with the tip of your index finger until you see the mileage displayed. Press and hold the trigger switch until the clock starts blinking the hour and tap to set. Press and hold again to set the minute then tap again.
Ride Safe |
| I got it......thanks yall |
