Posts: 348 Sturbridge, Mass | Trying to get it re-keyed to match ignition key ( I added the trunk) locksmith was wondering how it came out (they have not seen it yet).
Thxs...
Posts: 235 Kincardine, Ontario, Canada | I know it took my dealer over an hour to get it out. Apparently after removing all the bolts you have to gently pry the inner trunk out. It is glued or siliconed in about 5 locations, dollops about 1/2" diameter each. It didn't say that in the manual. |
Posts: 156 dinwiddie, va | The whole trunk pretty much has to be taken apart. don't remove it from the bike, but take the lic.plate frame, and "m" panel around taillight off first. then take the outer shell off. sounds harder then it is |
Posts: 348 Sturbridge, Mass | thanks, but no thanks- guess I'll get use to having two keys......
