Posts: 62 ESCALON CA. | ANYONE TRIED HAMMER S CAMS IN A VISION? I AM IN CALIFORNIA, SO THE DEALER SAYS WE CANNOT GET THE OTHER STAGE 2 CAMS, HOWEVER , I DIDN'T ACTUALLY HAVE HIM TRY JUST YET. THE ONLY REASON I AM ASKING IS BECAUSE MAYBE I WOULD NOT NEED THE CARRIER AS I WOULD USING LLODS CAMS. OR ARE LLODS CAMS JUST THAT MUCH BETTER? |
Posts: 40 Bellevue, NE |
I suggest you send kevinx a pm. |
Posts: 1340 Gainesville Fl Home of the Gators | The Lloydz cams are just that much better. Advertised numbers from Vic for the 106 S2 cams are
97/103, but at the rear wheel they do around 86/105 with a good pipe. The Lloydz cams do 107+/107+ with a torque curve that is MUCH longer on both sides of the peak |
Posts: 62 ESCALON CA. | THANKS! |
