| I have a set of Stage 1 Level 2 Victory pipes dealer installed, I have taken off all the clamps, bolts etc., muffler seems loose but will not come off, any suggestions? We hammer on the back bracket with a piece of wood but these suckers are on there. Ness mechanic says to turn them to compress a tab or something, unless we use a 5' pipe wrench and ruin these pipes they are not coming off.. |
Posts: 935 Rockford, IL | Hmmm...nobody has ver reported a major problem with removing their mufflers. Sure, some have been fairly tight and some effort is involved, but no reports like yours.
Um, gonna have to ask this. Did you remove the bolt off the stud on top of the muffler? About half-way back. And did you turn the muffler so the stud clears the bracket it goes thru?
Posts: 849 , FL United States | When we were installing King Bagger's center stand we did have the same problem, but not at the muffler(s). Where the crossover pipe meets the header pipes we had some difficulty getting them apart. But patience and a bigger hammer hitting the 2X4 won out and the pipes did finally separate.
After frustration sets in, you MUST use patience or you'll f#ck something up IMHO. |
| Thanks for the info, I had a buddy helping the first time who was sucking down adult juice boxes and he missed a fastner. Last night i got under it, saw the screw up and took bolts out and they came right off. |
Posts: 619 Southeast Iowa | Adult juice boxes are responsible for more than 1 mistake. Personally I mix my juice and if I spend too much time with "Jack" things can really get messed up. Glad to hear all is better now................. |
