Posts: 92 Eau Claire WIS. 09 vision | i'm putting in my clear lenses and 92 leds there not working right. turn work fine. tail light is on high if i turn bulbs around they dont light at all.... if i pull the brake fuse they work backwards bright on tail duller on brake... any ideas... thanks dave |
Posts: 92 Eau Claire WIS. 09 vision | heres a up date if i put in just one or two regular bulbs lights work fine also flash rate is normal |
Central Wisconsin | outdoordave48 - 2010-02-28 12:14 PM heres a up date if i put in just one or two regular bulbs lights work fine also flash rate is normal I'm thinking you might have to add a LED load equalizer to operate LED's only.
| I added some 10 ohm wire wound reisistors in parallel with all 6 rear led's. Solved my no cruise control and flash rate problem. |
Posts: 92 Eau Claire WIS. 09 vision | so if i add the 10 ohm res. to the bottom two lights it should make it work right do you get them at radio shack and can i wire them in down by the lights. also how much heat will they produce.... thanks dave.... |
| Well I added them to all 6 in the rear and did it under the seat towards the front. I tucked them in a hole. Kind of a good size bunch. No heat issues yet, but summer I'll know for sure. |
